Klipsch Pro Media Ultra 2.0 Speakers
  • bigbeark
    • Jan 2010
    • 661
    I was given these speakers, which have long-travel woofers and give amazing sound BUT the volume potentiometer is shot.
    I researched this on a Klipsch board, and the volume pot problem is universal.
    The volume pot is marked B503 and B50K.
    I found such a dual potentiometer on Mouser. I am assuming that RV122F-20-15F-B50K is the correct replacement. This is a linear rather than an audio pot.
    Since I have to dismantle the two-level board anyway, I'd like to replace the caps as well.
    They are 470uf 35v Orient brand (2 pieces) 10mm. Note the burned glue at the base, and the top part of the sleeve is missing on one. They are 85C and are right beside a heatsink(!)
    Next are 3 pieces 47uf 63v Capxcon 8mm 105C KM series caps
    There are 2 pieces 220uf 16v 8mm Orient beside the volume pot.
    There are 3 pieces 100uf 16v 6mm between the two boards.
    The Orients have no series ID and I assume they are GP.
    Can someone suggest suitable replacements and an opinion on the potentiometer replacement? Please see the attachments for more detail.
  • smason
    • 1652
    Re: Klipsch Pro Media Ultra 2.0 Speakers
    Have you tried cleaning the pot with good control cleaner?
    • bigbeark
      • Jan 2010
      • 661
      I read on the Klipsch site that the DeOxit fix works for some but not all.
      The DeOxit costs $15-30 plus postage, the Pot costs $3.45. The Klipsch users
      seemed to feel the original pot was of poor quality. One guy recommended the Alpha pot.
      • smason
        • 1652
        I use something called Nu-Trol. Works wonders.
        Obviously there's an issue with the quality of the pot due to how common the problemm is, but definitely worth trying if a replacement is hard to get.
        • smason
          • 1652
          • Maxxarcade
            • Jul 2006
            • 973
            I have two sets of these with the same problem. The pot does seem cheap. It's too easy to turn, like the wiper does not have enough tension against the resistive track.
            • 999999999
              • Sep 2006
              • 774
              Are you sure it's not a log pot? If right after the analog input, I'd want a log/audio pot.
              • Th3_uN1Qu3
                Believe in
                • Jul 2010
                • 6031
                • Romania
                It's linear in all those cheapies. They figured no one will tell the difference. Actually, even the volume control in winamp is linear by default, and i believe the windows one is too.
                A working TV? How boring!
                • 999999999
                  • Sep 2006
                  • 774
                  Also on a POT with that type of construction, (if it's like it seems to be) it's not hard to bend back the metal tabs in the back to open it up, clean it out thoroughly that way without buying a new expensive spray, and slightly bending a little more tension into the contact wipers. You might also take a pencil eraser or cloth and metal polish and clean up the contact points on the wipers. If there's hardened grease, a petroleum solvent should get rid of it (gasoline, etc).
                  Doing it might seem fiddly or problem prone but a few things I did this to in past years have worked fine. Since it is a quick and free thing to do, IMO it might be worth a try unless you're having trouble desoldering it and fear an extra cycle of desoldering if there's still a problem, might damage the PCB.
                  • LearningToRepair
                    How to know if LED driver is potentiometer dimmable?
                    by LearningToRepair
                    Hi!
                    I am looking to dimm 230V AC -> 12 DC LED driver with potentiometer. How do I know if I can dimm LED driver with potentiometer? I found from internet that 0-10V dimmable drivers can also be controlled with potentiometer. Is it so with every driver that says it is 0-10V dimmable? Or how do I know which are and which are not?
                    10-30-2021, 05:14 PM
                  • keldeo
                    Ultra low ESR. Much confusion!
                    by keldeo
                    Hi badcaps! So recently, me being a butterfingers, resulted in me dropping a graphics card and having the corner land directly onto a capacitor directly above the pcie slot on my Asus p5gc 775 board. Now this caused a pretty decent dent in the top of the can, so I've decided it'd ve best to replace it. However, I've ran into an issue. The current caps are Panasonic FJS, 820μf 6.3v. These are apparently "ultra low ESR" and these aren't manufactured anymore. So it seems I'm left with a few options. Put the dented cap back in, apparently it's ESR is 0.24 ohms, but the capacitance is...
                    09-03-2022, 12:56 AM
                  • Fripacks
                    Klipsch R-112SW manual
                    by Fripacks
                    Hi, I have Subwoofer Klipsch R-112 SW , someone could tell me what's the value of Resistor 13 , it's just beside capacitor 1000UF 80 volts and is connect on Zener ZD4, I don't have service manual.
                    11-15-2023, 01:49 PM
                  • MendipEng
                    Help to identify Tele-handler joystick potentiometer component.
                    by MendipEng
                    HI all.
                    I am trying to identify the following component.
                    It is a potentiometer of some sort.
                    It has been removed from a Tele-handler joystick.
                    I have never seen a component like it & dont know what its called to search for it.
                    It receives a 9 volt DC supply then gives an output from 3-9 volts depending on position.
                    I have multiple photos but the track inside is broken & needs replacing.
                    The problem being that the machine is over 20 years old & no longer made, the manufacturer no longer exists and there isnt any replacement units available....
                    08-27-2023, 03:46 PM
                  • debugtimog
                    Magneto-resistor Digital Output Potentiometer
                    by debugtimog
                    I am looking for a replacement for a Magneto-resistor type potentiometer model SMP-1504 by manufacturer SAKAE TSUSHIN KOGYO CO., LTD. I have already contacted them but they no longer manufacture this type.
                    What the manufacturer have are inductive types which they say is analog output and is not compatible with the Magneto-resistor type which is digital output. I am not sure why is it not compatible that but I did test it with according to specs input voltage of 5vdc and its out of 1.5v min and 4.5v max is according to specs also.
                    The...
                    02-07-2021, 02:57 AM
