Onkyo SR-TX705 issue
  • nerdbot
    • 56
    Hi guys,
    I was wondering if anyone might be able to shed some light on a problem I'm having with my Onkyo SR-TX705.
    I have a 5.1 setup, and it seems when I listen to Dolby Digital 5.1 sources (Dolby Digital icon lit up on the receiver), I will randomly get a high pitched "tick" out of the side surround speakers. It really seems to be random - I've tried replaying the scenes where I hear the noise, and it doesn't happen again. It seems to happen at any frequency (happens during loud scenes, quiet scenes, bass heavy, high-pitched scenes, etc). Sometimes, it'll happen back to back within a few seconds, other times it'll go upwards of 20-30 minutes before I hear it again. Sometimes I can definitely tell if it's the left or right surround, sometimes I can't.
    I've tried it in 2 different houses (i.e., completely different speakers, tvs, cables, a/v sources) with the same results.
    What I haven't tried yet is to see if it only happens in the surround speakers - that will be my next test. I don't know much about the internal workings of a receiver, but it sounds like something wrong with the Dolby Digital processing part of the receiver?
    I've already downloaded the service manual from elektrotanya.com, and I'm pretty comfortable with a soldering iron and poking around with a multimeter, so any advice/tests you guys could provide would be greatly appreciated. Thanks!
  • nerdbot
    • 56
    Re: Onkyo SR-TX705 issue
    Ok, I just confirmed it happens out of all speakers. I had the movie on pause for the last hour, went back to test it again (but left all 5 speakers connected). I hit play, and the ticks were happening rapid fire, going back and forth between the channels. I would say about 5-10 "ticks" in about 10 seconds, moving from speaker to speaker. It might've kept going, but my ears couldn't take much more so I hit pause again.
    • CDNBrewer
      Running out of Ideas, hoping someone smart can provide some for my ONKYO TX-SR353 Receiver
      by CDNBrewer
      Hello Everyone,
      I have an Onkyo TX-SR353 Audio/Video Receiver (5.1 ch with HDMI) that I am having a really hard time diagnosing and I'm about to throw this in the junk and go buy a new unit that is on sale until the 7th.
      Symptoms:
      • Intermittent (part of the reason why i'm having a hard time isolating problem), sometimes will work for 10+h at a time without issue
      • Original symptom was wife reported loud banging noise (like someone was banging on the wall with their fists) from the LEFT SURROUND speaker and then the unit shut off.
      • I swapped the Left and Right surround
      08-05-2025, 09:29 PM
    • ai.need.help
      Onkyo TX-8050 AV-Receiver no sound
      by ai.need.help
      I have a problem with my Onkyo TX-8050 Receiver. I got it from aftermarket and it was just delivered today.
      It doesn't play music. There is no real output from:
      pre-out
      amp-out A and B
      phones out
      The only real sound I hear is a humming from the speakers when I play a song from usb or select a analog source. And when stopping and starting songs from usb or switching sources, I hear a crack from the speakers.
      I tested with analog-input, usb and radio.
      I know that there is a common problem with...
      12-20-2022, 05:54 PM
    • benspawn02
      Anthem MRX500 - no sound. R2A15218FP issue??
      by benspawn02
      Dear Electronics Experts:
      I have the following problem I am trying to troubleshoot. Unfortunately, I have contacted Anthem themselves and even a local distributer but I am not having much luck. Also, I have scoured the internet and unable to obtain a service manual. The Anthem service rep has also replied that he is unable to provide me with any service documentation. I have performed numerous searches on the internet and cross-referenced a few other AV receiver makers (Denon, Marantz, Onkyo) and found certain similarities to block diagram...
      08-12-2023, 04:46 AM
    • rounin
      MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
      by rounin
      🛠 Original Issue
      ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
      04-19-2025, 01:18 AM
    • ugamazing
      by ugamazing
      12-17-2024, 07:05 PM
