Yamaha P-115 turn on but No sound - Doesn't turn off
  • daigs
    • Nov 2022
    • 18
    • italy
    I need to repair a P-115 yamaha digital piano with a strange behaviour.
    When I power on the piano from the dedicated on/off switch, the power led go to ON (red led), but the keyboard doesn't produce any sound, nor in the speakers nor in the headphones.
    When I try to power off (pressing the switch for at least 1 second), the keyboard doesn't power off, the red led remains ON. I need to unplug the adapter cable to switch off the keyboard.
    I checked the 12V voltage rail on the input PCB, after the power plug and it is OK.
    I checked also the power switch on the dedicated frontal panel pcb with a multimeter and it works fine (when pressed 0 ohm, when released open circuit).
    I tried to enter in test mode as described in the service manual, but the keyboard seems not to enter in that mode (C#2-F2-G#2 pressed at the same time and power on the piano, should follow a sound).
    How do you suggest to proceed?
    Thanks a lot.
  • daigs
    • Nov 2022
    • 18
    • italy
    Re: Yamaha P-115 turn on but No sound - Doesn't turn off
    Up!
    • daigs
      • Nov 2022
      • 18
      • italy
      Up! 2°
      • laidman
        • Nov 2023
        • 4
        • Costa Rica
        Were you able to get the piano to work? If not, check the capacitors in the vicinity of the 12v input.
        • laidman
          Yamaha psr ew400 piano loses sound
          by laidman
          Yamaha PSR EW400 piano intermittently loses sound and shuts down.
          Youtube people recommend verifying that the DC jack's solder connections aren't broken, and the replacement of a couple of capacitors in the vicinity of the DC jack. While these solutions might work, I'd feel a lot more secure if I had a schematic to help me check the status of the myriad components.
          Schematic and suggestions are welcome.
          11-18-2023, 05:13 PM
        • AlexVG
          YAMAHA CLP-550 without of sound
          by AlexVG
          Hi.
          I have an old YAMAHA CLP-550 without sound. (Some times I can get some kind of noise or distorted sound)
          I have replaced all green marked elements, but it gave me nothing.
          The IC12 chip LC9116A-105 (red marked) remains under suspicion yet.
          But it is custom YAMAHA's chip, and I can't find any information about it.
          Maybe somebody came across with the same issue?
          Any information will be very useful. I will be very appreciated.
          Thank you....
          06-08-2025, 09:29 AM
        • maleksa
          Yamaha MOX8 boot freeze and distorted sound
          by maleksa
          My Yamaha MOX8 synthesizer recently developed two issues.
          Firstly, after booting up, it operates as normal. However, after about 5 minutes, the sound starts to get distorted (broken up screeching sound) almost like putting it through a guitar distortion pedal. After a while, the distorted sounds will go away for a while and comes back. At times, the synthesizer will also freeze I need to power off and on again.
          Secondly, when powering off and on again, there will be times where the synthesizer will freeze during the boot sequence (freezes at the MOX8 Opening Screen),...
          11-07-2024, 03:28 AM
        • Pianomancer
          No sound from Yamaha digital piano
          by Pianomancer
          Hi All,
          I have a used Clavinova CVP 209 that isn't playing any sound from the keys or memory, neither on headphones nor line out. The speakers work OK from line in, and the rest of the lights and screen seem to work just fine.
          I have tried doing a factory reset by holding down the top key and turning it on, but that doesn't help. I did the RAM/ROM checks and they're OK. I checked the volume potentiometer and it seems OK (works with line in audio). I'm thinking it might be faulty DACs from the synth board (IC 28 and 29: ) or op amps. Not sure how to narrow it down more. I've...
          03-23-2022, 12:11 PM
        • Rupsenkind
          Yamaha RX-A1030 working, no sound output
          by Rupsenkind
          Hi all, I've started this new thread in order to avoid further polution of thread "Yamaha RX-A3010 working, no sound output"
          Just to recap:
          No sound through Audio and AV analogue inputs, only sound when 2ch stereo or pure direct is activated (so no sound when I e.g. choose 7ch of Hall in Munich etc.). Hoever when I connect HDMI I've sound in all options (movie, music, eyc.) First suspicion was the DSP chip/PCB so I bought a scrap 1030 with a good functioning PCB (in this one a driver stage was defective (PRT DC: 67), after I swapped the PCB I've performed a factory...
          07-10-2022, 03:15 AM
