Polk csi40 center ch speaker crossover caps replacement
  • budwich
    • Jul 2015
    • 3097
    Did a "gross" impedance measurement of the inputs on my polk csi40 center channel speaker. It showed about 4ohms. Seemed kind of low. There are two midrange drivers and one twitter ... 2 way system.
    All measurements at the drivers seem ok in the 4 - 6 ohm range (the two mid range are in series).
    Anyway, in the crossover on the tweeter side, there are two caps in parallel basically leaving an inductor .... "nice simple setup", especially when no schematics around. The question is finding a replacement. One is a TI .47uf met 100vdc while other is a 9.1uf 50v electrolytic NP. I can find the .47 but not so much with a 9.1. I guess the question is what can the 9.1 be replaced with... a higher capacitance or lower... or can I just combine the values and find something with one capacitor that is close ... again higher or lower?
    Thanks with any guidance on this, as for what I have read cross over design is almost a "black art"... :-)
  • lti
    • May 2011
    • 2557
    Re: Polk csi40 center ch speaker crossover caps replacement
    Lower capacitance would be safer, but you might create an audible dip in the output volume near the crossover frequency. You can make your own parallel combination to make 9.57uF (or as close as you can get). The tweeter section of the crossover is basically a high-pass filter, but there's usually some other stuff added (at least an attenuator because tweeters tend to be louder than midrange/woofer drivers).
    Is there a reason for changing the caps besides the low impedance you measured? Some speakers have some pretty low dips in the impedance.
    • budwich
      • Jul 2015
      • 3097
      thanks for the guidance. One cap wouldn't measure (.47) although I might have damaged it trying to isolate it from the board to get a measurement. As for reason, I compared the impedance tests with the other speakers in the system (9) and it seemed significantly different from the other ones which seemed closer to stated values... off by an ohm or two. I know that a "dc impedance" as provided by a DMM isn't that great but figured that it should at least be closer as opposed to "half" the value. The speaker is pretty old so I figured caps are the most like source of a possible problem. Another thing is the speaker's sound seemed somewhat "harsh" at times (not the best hearing) as the highs seem distorted but not all time time.
      As for the circuit, there is only a low value resistor (rx5w0r5j) in the high frequency side of things. No adjustable attentuator. The resistor measures very low... about .3 ohm but if understand the part number, its less than an ohm.
      • budwich
        • Jul 2015
        • 3097
        I replaced the .47 but only got one that is 600v rated which makes it larger (fit on the board took a bit of lead bending). The speaker appears to sound better although it could be just a "psychological high" so to speak. :-) I am waiting on the other cap replacement as it was 20% off its marked value.
        • 30Cal
          Peavey SP5 Speaker Crossover.
          by 30Cal
          Greetings. Having an issue with extremely low output to tweeter. Replaced driver and fuze. As far as I can tell every component has relatively low ohms and no opens. I only use the speakon connection. Woofer operation is OK. Tried tweeter on woofer connection and sounded fine. Jumped the resetting fuze, no difference.
          Considering speakers are 20+ years old (MADE IN USA) and been through hell and back I really can not complain.
          Redid a few years back with Eagles influence.
          Any information would be greatly appreciated.
          Thank you for your time.
          09-07-2025, 03:53 PM
        • r2digital
          TDGAUDIO NFC-83A ceiling speaker crossover repair(no output)
          by r2digital
          Hey guys, im trying to figure out why my ceiling speaker has no output from the woofer or tweeter. I cannot seem to get a resistance at the main input speaker terminals but i did measure resistance at the woofer and at the tweeter wires individually and everything seems to be OK. Ive done a little bit of troubleshooting on my own and when i was probing the negative terminal in combination with any component (PTC fuse, the capacitor, and any of the resistors) on the crossover i get no continuity what so ever. However, when i take the same model speaker but a fully working one and i probe the negative...
          07-31-2021, 10:18 AM
          HP ProDesk 600 G5 + Bluetooth Speaker 400 ProDesk 600 i7-9700 Specification for Upgrade or Repair
          This specification for the HP ProDesk 600 G5 + Bluetooth Speaker 400 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + Bluetooth Speaker 400 boardview and ProDesk 600 G5 + Bluetooth Speaker 400 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
          09-12-2024, 02:30 PM
          HP EliteBook 840 G6 + Bluetooth Speaker 400 Notebook 800 Specification for Upgrade or Repair
          This specification for the HP EliteBook 840 G6 + Bluetooth Speaker 400 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 840 G6 + Bluetooth Speaker 400 boardview and 840 G6 + Bluetooth Speaker 400 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
          09-06-2024, 06:00 PM
