Technics SL-1200MK2 internal grounding
  • MartinConnolly
    • Feb 2022
    • 11
    I have recently bought a pair of 1988 Technics SL-1200 Mk2 DJ turntables. All original components inside and all still work!
    But, they have been 'internally grounded' which is a common mod that some DJs do which removes the ground wire and just connects the turntable chassis to one of the sheilds on the RCA phono cables.
    Now, Technics say this shouldn't be done because the outputs from a phono cartridge are balanced positives and negatives, not unbalanced signal plus ground.
    So, I plan to remove this mod.
    However, looking at the back of my chosen cartridge - a classic Stanton D680AL, there is a 'ground strap' connecting one of the negative pins to the metal chassis of the cartridge.
    I'm confused. Isn't this doing the same thing? The metal of the cartridge makes contact with the metal headshell and tonearm, so Isn't the whole chassis of the turntable grounded through this strap?
    Your thoughts please?
  • MartinConnolly
    • Feb 2022
    • 11
    Re: Technics SL-1200MK2 internal grounding
    I may have just answered this myself. The Stanton is supplied with threaded plastic spacers for the retaining screws, so it becomes electrically isolated from the headshell. I still don't see the point of the 'ground strap' on the back though.
    • redwire
      • Dec 2010
      • 3900
      It's a battle between the turntable's earth-grounding, and the phono-preamp's earth grounding. Who has or does not have it. At least/most one end needs it.
      The tonearm, chassis, cartridge's headshell can pickup mains hum and noise, and require to be earth-grounded to make an electrostatic shield.
      Older turntables (2-prong power cord, no PE ground) can't do this so require a chassis ground connection through the loose ground wire at the preamp.
      Newer turntables with 3-wire power cord, they (tonearm, chassis) are earth-grounded, and you can verify with an ohmmeter.
      Ultimately, a cartridge's audio outputs are isolated/floating. They usually get some form of ground reference when plugged into the RCA's at the phono-preamp end.
      You don't want a ground-loop between the audio ground and the earth ground, which will happen if you do the DJ mod/Stanton ground strap (on a 3-prong TT) AND the phono-preamp (RCA's) is also earth-grounded (3-prong power cord). Does the preamp have a 2-prong or 3-prong power cord, you can check ohms between the RCA jacks and 3rd prong PE ground on the power cord.
      So at least 4 permutations of turntable grounding to understand.
      • MartinConnolly
        • Feb 2022
        • 11
        Both the turntable and mixer are 2-prong power. No earth, with the box-within-a-box double insulated symbols.
        I must say, it sounds stunning, with dynamics and balance that put my cheap Numark CD players to shame, so there's a lot of 'if it ain't broke don't fix it', but at high volume, when I hold the headshell I can hear a faint crackle from my body static leaking into the output, which I assumed was because of the internal grounding.
        • barry101
          Apple 820-3662 VCore shorted to ground.
          by barry101
          Hi, Would appreciate some help.
          I have an Apple Late 2013 15" A1398 MacBook Pro with Logic Board 820-3662.
          Get charger light but no fan spin or chime. No liquid damage.
          Found PPBUS and VCORE both shorted to ground. Other rails were ok.
          Removed VCORE MOSFETS U7310, U7320 and U7330. Found U7330 was in fact shorted.
          With the 3 MOSFETS removed, get PPBUS and fan spin. VCORE is still hard shorted to ground (0 ohms).
          Attempted voltage insertion on VCORE to locate short using bench supply set at 1.0 VDC and 4.95 Amps (max current for my...
          06-24-2025, 07:34 AM
        • Chaks
          Ground Plane For 5dBi ISM Band 865-870Mhz Embedded Ceramic Antenna
          by Chaks
          TAOGLAS ANTENNA MODEL: ISPC.86A.09.0092E
          The specs says ...
          High antenna efficiency 868MHz ISM Band
          5dBi Peak (when placed on 30cm x30cm ground plane) - Broadside to Zenith Radiation Pattern
          The antenna is 50x50 mm square and How do I fix it on the Ground Plane of 300 x 300 mm (aluminium sheet 3mm thick).
          1. Should I Fix it with a glue.
          2. Should I fix it with a double side adhesive tape
          3. Should I fix it with Screws (the screw head may just clamp the antenna to the aluminium...
          12-09-2024, 11:06 AM
        • reformatt
          Lenovo NM-A921 (Yoga 900-13ISK2) dead
          by reformatt
          This machine has been in a few times with an intermittent fault of not charging. Motherboard is NM-A921 (https://www.badcaps.net/filedata/fetch?id=2051581)
          So back again now, not working at all. Previously the adaptor had been replaced along with the DC charge port. This is one of these trapezoid shaped orange USB ports that Lenovo were using prior to going USB-C. It has 4 pins, but the DC connector jack on the PCB has 5 pins.
          Fault presentation was the adaptor is only producing 5.2V, not 20V and this isn't reaching the input of the NVDC charger (PQ5/PQ6). There are 5...
          02-05-2025, 05:24 PM
        • Rolin
          Dell Laptop - over 14V between Chassis Ground and Circuit Ground?
          by Rolin
          Someone brought me a Dell laptop that had a loose power jack inside (power jack on a cable, not soldered to motherboard). Once disassembled found one of the wires was broken off the power jack. I replaced the jack and it won't turn on, but the metal shell of the jack inadvertently touched the metal hinge and suddenly it got power. I checked voltage from the metal chassis ground and the circuit ground and I get over 14V ? Has anyone seen this before? Typically is it some kind of filter cap that shorted? Very strange...
          10-30-2022, 10:18 PM
        • gaby_64
          MC-G01 Canon Maintenance Cartridge Rom request
          by gaby_64
          Hello, I am looking for a MC-G01 eeprom dump with low utilisation count. I need it to reset my maintenance cartridge. Its not actually full, I mistakenly left the service lock on and then proceeded trying to troubleshoot what I thought was a printhead issue, I did serveral deep cleanings with no ink actually flowing out. After realizing my mistake I also did an ink flush that I cancelled mid way, this still incremented the waste ink cartridge significantly to the point that the printer won't let me print anymore.
          If anyone has such a rom to share, it would be greatly appreciated....
          10-09-2023, 12:25 AM
