DENON DCD-890 service manual?
  • Francesc V.
    Tempus fugit
    • Nov 2022
    • 231
    • Catalonia
    Re: DENON DCD-890 service manual?
    I am little bit lost in translation :-)
    - What's an upside down test?
    - How you notice the motor might have problems?
    • jons
      • Feb 2014
      • 59
      • Latvia
      This
      Originally posted by stj
      turn the player upside-down before you play the tracks - see if it fixes it
      Usually they are little bit louder than normal, and you can test bushing play by hand.
        • 31055
        upside-down test.
        put in the disk and flip the player over onto it's top
        if it works the player has a worn or sticking frame or head assembly.
        the test works because your taking the weight off of the mechanism.
        • Francesc V.
          Tempus fugit
          • Nov 2022
          • 231
          • Catalonia
          I am start thinking that maybe it's a mechanical problem.......just a guess
          The original CD's that is reading, they jump in the same place all the time
          As an example from one CD: on track 2, on track 7, 18 & 20
          Rest of the time and tracks it reads and sound perfect.....
          In case I would like to buy the mechanism. Where could I find it? So far I haven't found it on aliexpress
          Here you have it.
          • jons
            • Feb 2014
            • 59
            • Latvia
            Check plastic sledge and other side of that gear for cracks, and of course clean and lube metallic rod on which laser travels.
            • Francesc V.
              Tempus fugit
              • Nov 2022
              • 231
              • Catalonia
              #26
              Thanks!! Do "they" sell replacements for these parts?
              P.S: I've ordered a second hand mechanism from Ebay......fingers crossed. Let's see if there is any difference.
              • jons
                • Feb 2014
                • 59
                • Latvia
                #27
                No, only whole mech if you are lucky. And even then it most likely will be chinese knockoff.
                • Francesc V.
                  Tempus fugit
                  • Nov 2022
                  • 231
                  • Catalonia
                  #28
                  From the time being I have the certainty that the CD mechanism works perfect. I have exchanged it with other Cd reader that uses same conexions and both works perfect. So I know for sure that is something wrong in the DENON PCB.
                  I am able to read the CD info (TOC read), but not playing it. It tries it but maybe it has not the right power.......
                  Any idea suggestion where to start from?
                  • Francesc V.
                    Tempus fugit
                    • Nov 2022
                    • 231
                    • Catalonia
                    #29
                    Indeed it was related with power (amplifier transistors)*.
                    - I replaced CXA1372S and 2 operational amplifiers (IC105 and IC106). Same result........reading TOC and some intermittent reading in original CDs (jumpy sound).
                    - I realised that R185 was reading about 33k instead of 100k, so I've replaced C168 (75pf) (they are connected in parallel)........then resistance reading went back to normal.
                    - I replaced TR116,TR118 (BC369 PNP) with S8550. They are not pinout compatible, but I managed it.
                    - I've replaced TR117 (BC368 NPN) with S8050. Again changing from ECB configuration to EBC.
                    The 3 transistors were "ok" but with a lot of HFE difference........so the new ones have a really closer HFE.
                    BC369 (1 & 2)
                    Hfe 183 & 260
                    Ie - 6.4mA & 6.4mA
                    Ube - 621mA & 608mA
                    BC368
                    Hfe 27
                    Ie - 6.2mA
                    Ube - 614mA
                    ICEO - 13mA
                    ICEs - .54mA
                    The CD player is back to life.
                    * If you look closer at the PCB behind the color is more "brown"......some burnt there.
                    Perseverance and countless hours measuring like a monkey without any knowledge.
                    However if I look it into perspective, I should have paid more attention to that burn section from the very beginning.
