ELBA tower fan keeps blowing resistor
  • SturmGhost
    • Aug 2013
    • 9
    I have the same fan (Honeywell HO-5500RE) and I'm also missing the 5 VDC rail. I injected 5 V via an USB charger and the fan started working again. I know a little bit about electronics and also designed and build some PCBs but this 5 V power supply looks funky to me (looks like they saved every penny possible). Like mentioned before the 5 V are connected somehow to mains voltage on one side? I also check D1, 2 and 3 which are fine and R1, 2 and 3. I changed R3 for two 1 Mohm resistors in series to replace the old 2 Mohm resistor which only showed me 1 Mohm on the multimeter. Other then that I don't know what to check. Maybe someone can help or explain to me how the 5 v are created? Nothing looks burned or blown.
      • 31055
      this has schematics
      • SturmGhost
        • Aug 2013
        • 9
        This is only the pwm power switch, which is working fine. Or does it create the 5v? I'm not sure.
        E: Sorry I misunderstood the purpose of the IC. How can I check if the IC is working?
          • 31055
          i think it uses the inductor to generate 5v
          • SturmGhost
            • Aug 2013
            • 9
            I changed the OB2223AP IC and now the fan is working again.
            • jinu_j
              by jinu_j
              Hi
              05-03-2025, 10:51 PM
            • mikey5791
              by mikey5791
              Hi to all forum members,
              12-26-2024, 04:55 AM
            • agent0bean
              Acer Aspire a715 - no power, 10ohm resistor keeps blowing on VCC
              by agent0bean
              I got Acer Aspire A715-42G, no 19v going through the DC-IN mosfet. I also checked the components/power rails downstream and no short detected (gpu and cpu rails are at 2-10 ohms)
              I have checked that there's no gate voltage on the DC-IN mosfet, so I checked if PUB1 has power.
              Turns out there's no 19v going into PUB1 VCC caused by a burnt 10 ohm resistor (PRB12 - 19v stops here).
              Replaced the part but it burned when I plugged in the charger - telling me there's something pulling high current.
              I checked the resistance of PCB16 and it was fine.
              I measured the resistance...
              09-20-2024, 02:18 AM
              HP Z240 Tower Workstation i7-6700 Specification for Upgrade or Repair
              This specification for the HP Z240 Tower Workstation can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Z240 Tower Workstation boardview and Z240 Tower Workstation schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
              09-12-2024, 03:44 PM
              HP Z240 Tower Workstation i7-6700K Specification for Upgrade or Repair
