Philips toothbrush 4100 (HX369BK) - motor getting hot
  • d00m178
    • Jul 2025
    • 5
    • Portugal
    trying to fix Philips toothbrush 4100 (HX369BK)
    The battery started draining quickly.
    After disassembling it, I discovered that the motor gets very hot when brush is off, which is apparently causing the battery to lose charge.
    The motor is connected to contacts M1 and M2.
    When I turn on the brush, 0.4V appears on these contacts, and the motor starts running as expected.
    But when I turn off the brush, the voltage changes to 3.8V—exactly the same as the battery.
    The motor gets so hot you can't touch it. And after 5 minutes, the battery drains to 0V.
    (To charge it, I unsolder the battery's positive terminal and charge it using a TP4560)
    That's why I noticed this 6-pin chip (pin 1 also shows 3.8V)
    I think it's some kind of LDO or something. Maybe it needs to be replaced so that the contacts don't show such a high voltage when off?
    chip marked - 8517C
    Please help me identify this chip so maybe I can order it and replace..
  • osman68i
    Philips Coffee Machine PHILIPS EP5441 1.9.30.330.0
    by osman68i
    I need some advice about mainboard of Philips Coffee Machine PHILIPS EP5441 with 1.9.30.330.0
    u2 is shorted. I can only read MX1 . cable goes to display panel....
    11-28-2025, 01:55 AM
  • martonmiklos
    Dyson DC45 trigger board burnt brush motor driving SO8 IC
    by martonmiklos
    Hi fellows,
    I am trying to repair a Dyson DC45 battery powered hoover.
    There is a trigger board in it which hosts an Attiny48 and some power stage to drive the brush motor.
    Unfortunately a SO8 component burned to hell in it together with a 0603 resistor and the IC could not be identified.
    The Attiny output looks to be survived the problem because when pulling the trigger it outputs high for a while and then turns off.
    It is likely that it measured the current on the R10 shunt and this is why it is shut down.
    I have attached...
    06-29-2024, 12:21 PM
  • juergenb
    Nescafe Aeroccino, still fails with new Motor (red flashes only once)
    by juergenb
    i am asking for some Help.
    I have one of these Nescafe Aeroccino (Milk Frother) things with a bad motor.
    The Motor didn´t start anymore and internet is full of users just swapping the motor for a Mabuchi RF-500TB-12560.
    So i got a few of these from Banggood.
    I swapped the motor and now i have a new fault condition.
    In a working Frother you would press the start button, it will light red and work for a few minutes.
    If you press longer it will light blue and just mixup the milk.
    With the new Motor it just starts...
    03-23-2021, 11:24 AM
  • sbt123
    charnwood w821 mini wood lathe motor problem
    by sbt123
    hi there,im having a look at repairing a wood lathe for my dad,(charnwood w821)the problem is when turning up the variable speed control,the motor starts to stop and start by itself,if i continue to turn up the speed it will trip the mcb in the consumer unit,there is also a slight smell of burning from the speed controll box.,Another strange symptom is the lathe can be unplugged from the mains after switching it off and the motor will spin a couple of times by itself,so far ive put a new speed controll potentiometer on and new motor brushes,ive also tested the motor windings and everything looks...
    10-27-2024, 03:43 AM
  • Sharpa
    Repair attempt Philips 55OLED804/12
    by Sharpa
    I bought a SH Philips 55OLED804/12 TV with known defect in an attempt to repair it for personal use.
    The symptoms when bought: Philips logo appears then tv turns off
    Things tried so far:
    1. Powering it on: Philips logo shows on the screen, sometimes with some minor artefacts then shuts down. Red status led flickers rapidly into two batches then repeats
    2. Put it in recovery mode by pressing joystick down then plugging it to mains: The tv shows the logo then shows the android animation along with some minor artefacts on the screen...
    11-22-2025, 08:30 AM
