LG F1480YD5 PF error code - powers off after 5 minutes of use
  • KevinUK
    • Aug 2024
    • England
    I'm getting a PF (power failure) error code when doing a tumble dry or wash cycle after around 5 minutes of either (the whole machine powers off).
    The machine is 12 years old.
    After some Googling it sounds like I need to replace the PCB but I can't see anything on my machine that looks like a PCB on similar models that I've seen on YouTube, I was expecting to see a large rectangular circuit board.
    Where should I be looking and any ideas on if it could be a different faulty part?
    Thanks!
    • Jul 2011
    • 6070
    Where you see the control knob and the digital display look at that section and see what it takes to remove it from the machine
    See if the front of the machine can be removed from the machine but be careful with the wiring and the tubing in this section and do not be tempted to just rip thing apart this is how parts get damaged and broken
    Also if it has wiring plugs and if there are several plugs make sure that you take pictures of and if any of them are exactly the same then make sure that you take picture of each one and make sure that you mark them somehow to make sure that the plugs stay with the plug that should be connected there is nothing worse than plugging it in the wrong place bad thing can happen because of not taking the time to marking where things go
      LCD LED TV Service Menu Codes
      TCL LED TV Service Menu Code
      LG LED TV Service Menu Code
      10-31-2024, 03:58 AM
    • CG2
      Janome DC3050 Sewing Machine Pedal Resistance
      by CG2
      OK, this is a long shot. I got this sewing machine cheap because it's end of line, ex-display, and had no pedal. The genuine pedal costs £60, while Ebay knock-offs go for around £15. So I went for the knock-off, it doesn't work, and I'm not sure whether it's the pedal or the sewing machine that has the problem.
      Now this is an electronic machine, unlike the old fashioned sort where the pedal was a big resistor in series with the power to the motor. Here, the pedal is just (I think) a variable resistor fed with a 5 volt supply, and limited to a current of 5 milliamps. Assuming that...
      04-14-2023, 07:53 AM
    • Curtissimo
      HP EliteBook 850 G8 - Error code / Caps Lock permanently on and blinks twice every 6 seconds
      by Curtissimo
      Hi everyone.
      I have a HP Elitebook 850 G8.
      Serial: 5CG2324XM0
      ProdID 6L8D5EC#ABA
      It has a Winbond W25Q256JVEN Chip.
      I need to remove BIOS Password.
      I made a dump with an CHA341A programmer and NeoProgrammer 2.2.0.10.
      Attached my dump.
      I also used the HP Unlocker tool to create an unlocked file (I followed the guidelines)
      I also downloaded latest HP BIOS Update (SP158137) which includes 3 .bin files. I found the Number T76 in my original dump, so I used: T76_01210000.bin
      What I did:...
      08-26-2025, 04:42 AM
    • Wutru
      HP Elitebook 820 G4 BIOS repair assistance required
      by Wutru
      Hi guys,
      If someone would be able to provide some expertise, I'd be very grateful.
      BIOS Corruption - Cause
      So I managed to corrupt my machine by installing linux and enrolling custom secure boot keys. I did choose to enroll the Microsoft keys as well, to prevent any potential bricking due to 3rd party drivers from HP being signed with those keys.
      After doing that, and rebooting(it did boot, powerLED, fanspin etc.), the laptop did not give any video output on the LCD or video connectors. I think I was able to get in BIOS and trigger the beeper by pressing ESC....
      09-06-2025, 10:32 AM
    • Soulzink
      Samsug washing machine. Power supply DC41-00189a board issue
      by Soulzink
      I am trying to fix a samsung washinmachine power supply main board.
      I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
      Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
      The power supply board reference is the following: DC41-00189a
      I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
      04-19-2025, 06:26 AM
