I need chip identification help. ab238p1n692-65e4
  • mbnaso
    • 3
    • usa
    I am new to the forum and may be posting to the wrong area. I did do a search and it may be that I should be searching for a smaller set of numbers to identify it. I am a newbie into electronics repair as a hobby. Does anyone have a good source for obscure integrated circuits and component's in general. This is one of the 2 chips I am looking for. ab238p1n692-65e4. I think it could possibly a Bluetooth chip? I have a Bluetooth shower speaker the has less and less battery life. The Battery checks good. I wanted to replace the Leds with a non emitting diode or a resister, I to save the charge. I think 20 ohms should be sufficient. Just trying to figure out the circuit. I would appreciate any feedback
  • jiroy
    • Jun 2016
    • 2416
    • Lebanon
    Another chinese manufacturer , seemingly on the rise but no real documentation yet .. and a chinese translator is a must.
    https://www.zh-jieli.com/
    • kasfamily
      • Aug 2014
      • 774
      • Russia
      The chip model is 65E4, and completely AC6965E
      • DynaxSC
        ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
        by DynaxSC
        Hi
        I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
        08-04-2025, 12:20 PM
      • e-repair
        Chip identification on hp omen 17cb1008tx
        by e-repair
        Hello !
        i have an to repair an hp omen 17cb1008tx.
        i have a short on a power supply chip, sempt powering the chipset. the chip was burned, but i can read the chip making code but i can't find any references. chip reading is AWSBVC. the chip have an output directly on a coil. sempt to have no damage on the rail behind but can't confirm.
        can you help me find a reference for this ic ?...
        09-23-2025, 03:38 AM
      • Sunday1302
        Need help with GIGABYTE B550 UD AC REV 1.0 chip identification
        by Sunday1302
        I removed this chip with markings "14 8A SA4" between an HDMI port and a USB port that was faulty. I need to replace it, but I have not been able to properly identify this chip using the markings provided on the chip itself. If anyone is able to provide information regarding this chip, I would greatly appreciate it....
        10-26-2025, 02:35 PM
        by SMDFlea
        Bad...
        09-02-2021, 04:40 PM
      • BMCappelletti
        Asus Chromebox CN62 - wrong chip put on BIOS reader
        by BMCappelletti
        Long story short:
        - dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
        - gave the computer to his son a couple years later
        - son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
        - too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
        (seems like the story was not that short)
        He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8...
        01-08-2025, 07:27 PM
