ELECTROLUX DISHWASHER IC LNK362GN HELP!!!
  • NConstantinou
    • May 2017
    • 348
    • Cyprus
    i am checking this ic LNK362GN and between Source to Drain i get 013 reading in diode mode. I am wondering if this is a correct value.
  • lotas
    • Jan 2016
    • 4785
    • Russia
    The microcircuit is faulty.
    • tofik
      MOSFET equivalent K8A60DA
      by tofik
      Hello guys,
      I have a shorted MOSFET K8A60DA with the following characteristics:
      Type Designator: TK8A60DA
      Marking Code: K8A60DA
      Type of Transistor: MOSFET
      Type of Control Channel: N -Channel
      Maximum Power Dissipation (Pd): 45 W
      Maximum Drain-Source Voltage |Vds|: 600 V
      Maximum Gate-Source Voltage |Vgs|: 30 V
      Maximum Gate-Threshold Voltage |Vgs(th)|: 4 V
      Maximum Drain Current |Id|: 7.5 A
      Maximum Junction Temperature (Tj): 150 °C
      Total Gate Charge (Qg): 20 nC
      Rise Time (tr): 25 nS
      Drain-Source
      07-19-2023, 05:18 AM
    • Babbar
      Electrolux Ultrasilencer and UltraOne vacuum cleaners not starting
      by Babbar
      Hi all!
      New to the forums, this is my first time posting so hoping to do a good enough job making sense.
      I have two vacuum cleaners having the same issue of not being able to start on their own but when they get going (by manually shorting power to the motor on the internal PCB) they will keep running and also allow me to switch on and off again for a while using the power switch until the issue returns.
      The models are below and i will attempt to attach pictures of both sides of the PCB from one of the machines (they look basically identical).
      11-26-2023, 01:21 PM
    • jkucukov
      Asus ZenBook 13 UX333F External Short - Fast Battery Drain - Need Help
      by jkucukov
      I'm trying to see if someone could help me with my Asus Zenbook 13 UX 333F with given symptoms that I've experience during a recent external short.
      During last laptop charge, as I was moving the DC power supply, I caused the two leads (+ -) to touch. After that event the laptop stopped charging and pulling amps form the power supply. The only way the laptop will come on is with the power supply connected and the battery having some charge to it, battery drains immediately after short operation (it gets to Windows log in screen before it shuts off). The laptop would power on, show...
      02-05-2025, 09:27 PM
    • tantr13
      Lenovo Ideapad 5 14ITL05 not powering on
      by tantr13
      This is my first post so I'm hoping to get some help on this awesome forum. As a preface, I'm an amateur at electronics, especially troubleshooting complicated devices like laptops. However, I'm trying to develop a skill for it so I can learn how these devices work and how to repair them without continuing the wasteful tradition of throwing them away and buying new. 🤮
      I've had a Lenovo Ideapad 5 14ITL05 for a few years now, with motherboard LA-K321P. I would never leave it plugged in unless I was using it, and always turned it off after I was done, but last week...
      06-28-2024, 06:28 PM
    • Wodger
      Electrolux EWT904 (Simpson brand) - Top Loader Washing Machine
      by Wodger
      Hi Everyone,
      I'm looking for a circuit diagram layout for the power board on this machine, so I can attempt to troubleshoot, As per the sicker on the back:
      SIMPSON/Electrolux
      W2104A-V06
      I've repaired and replaced this board once but now I have 2 dead powerboards. Usually the capacitors blow on this design, but recently I found no problems with the capacitors and finally found the offline switcher (LNK306PN) had burned. On replacement, one board worked for a while but now is dead again (no beep when powered up from wall supply), and the other older board...
      02-01-2024, 04:28 AM
