Problem in hood board after overvoltage
  • Wolf1977
    • Jul 2023
    • 59
    • Greece
    hello everyone on the hood board had broken the power line and the varistor I changed them It lights up normally but has three speeds for the motor and an output for a 220 volt alternating lamp which are driven each by a triac T405Q and had a resistor 102 1000ohm pov were burnt I replaced them I put load the coil of a 220 volt relay but nothing works no output from 4 meters with base the negative pole of 5 volts I measure based on the negative pole of 5 volts at the edge of the resistor from the output of the microcontroller and extension to the gate of the triac but apparently the triac does not conduct does the load play a role i am thinking to use a fan 220 volt as load is better or it doesnt play role ? I just want to test it if it works because its motor is in another place and I will go there in a week.
    the commands of the inputs working normal speed 1 choise 2 and 3 from buttons
    microcontroller is ht48r05a
  • прямо
    TRIAC circuit
    by прямо
    Anyone is familiar with a TRIAC circuit?
    I came across this schematic, and I built it, but I can't seem to figure it out why I'm getting a low AC voltage output at the TRIAC terminals.
    With 230V AC hot side at the TRIAC MT2, I measured 60V AC between MT1 and neutral side when the comparator output LED indicator is on, and 20V AC when it is off.
    Same result if 230V AC hot side is at MT1, and I measured between MT2 and neutral side.
    My heating element doesn't work with 60V AC. It's not even getting hot and the thermocouple amplifier output is a...
    04-27-2024, 02:12 AM
  • gabri2211
    external hd Seagate, broken down the +12 volt and USB 3.0 SATA board
    by gabri2211
    Hi to all 😎
    I'm looking for any useful information to repair this interface (I have attached the image).
    On this board I read E3215-1215A_4D.
    This is the small plate inside the HD enclosure that allows to connect a 12 volt power supply, interface the disk with a USB 3.0 socket and is connected to the HD with the SATA connector.
    If any of you have found a burnt or short-circuited component in a circuit like mine​, if you have useful diagrams for the repair, or even better a description for the tests at the test points, I would be very grateful.
    in particular...
    11-12-2024, 08:08 PM
    Using a 5 volt @ 12 amp switching power supply and two USB doctor volt / amp meter to three IPads on one power supply
    by sam_sam_sam
    I have been wanting to do this project for some time using a Mean-well switching power supply that I bought at least ten of them that were originally in a device that was abandoned for some reason they were listed new but removed from equipment that was never used
    I do not understand Mean-well the capacitor next to the voltage reference ic chip was a brand that is known for failure over time the other capacitors are brand name needless to say it got replaced before I even powered it on for the first time
    I used a four USB outlet and electrical plate that is made for...
    08-03-2024, 07:54 PM
    I need to order some 1000uf @ 16 volt it has to be 8mm in diameter what is a good choice
    by sam_sam_sam
    Here is the page of capacitors that I can choose from what is a good choice for a FSP 400-60GLC
    https://www.digikey.com/en/products/...Xmc1YPJ6BlESoA
    I try to use a 565-1664-ND which is a 10mm in diameter unfortunately it will not fit because there are two of them the same size and value and there is no room and they go to two different circuits not in parallel...
    08-03-2024, 02:54 PM
  • bembeno
    Adapter 24 volt problem
    by bembeno
    I have 24 volt adapter when i measure its output with multimeter i found the 24 volt is good put it dosent charging the battarey of Electric wheelchair i tried another adapter and charging thr battarey what can be the problem
    06-06-2024, 12:32 AM
