HP LCD Replacement FET's
  • madamorr
    • Jul 2010
    • 5
    I love this place...
    Well on to the question.. I am repairing a HP LCD monitor and the FET's are bad. The Part number is NIKOS P5506BDG ( )
    I was wondering if it would be okay to replace that part with a Fairchild Semicoductor NDB5060L ( ) The parts have similar characteristics.
    Or do you know where I can find the Original NIKOS FET?
    FYI: I have already replaced all the Caps on the power supply with Rubycon caps.
    Thanks in advance,
    Michael
  • Rtech
    • Jul 2010
    • 1095
    Re: HP LCD Replacement FET's
    I would consider IRF540s,higher voltage and current rating,easily obtained,and have used these in this type of application as replacements, with no problems.
    • madamorr
      • Jul 2010
      • 5
      Thanks for the reply.
      Any particular manufacturer? I see the IRF540 supplied by Vishay, Harris and several others. Mouser has Vishay and Fairchild, Newark has Vishay and International Rectifier. Jameco does not list the manufacturer. Digikey has several vendors as well.
      Thanks again,
      Michael
      • jetadm123
        • 2169
        Welcome to the forum! Just a minor detail.... you posted your question in the wrong section. The "Troubleshooting Computer Displays" section would probably have gotten you more responses. However, if you're located in the USA and do decide to purchase the IRF540, then buy them through digikey because they offer dirt cheap shipping via USPS First Class Mail. Typically, it's around $2.50-$2.75 and they process your order fast!
        • madamorr
          • Jul 2010
          • 5
          Thanks for the suggestion as I will order the replacement parts tonight from Digikey
          Michael
          • kris760
            • Sep 2013
            If your looking to repair this screen do not use what you recommended. IRF540 was way to big of a mosfet. almost double the size. Tried to make it fit and ended up breaking the whole board.
            • redwire
              • 3912
              Sad to hear you busted up the board
              The P5506BDG is a DPAK (TO-252) package, electrically it's 60V, 10A, 55mohm, 32W, logic level. So a TO-220 package part (IRF540) is plain wrong
              What I think might work:
              STD20NF06L looks like a good substitute.
              MTD3055VL has slightly higher on-resistance but otherwise a close match.
              • reformatt
                by reformatt
                07-31-2025, 08:37 PM
              • the_rem
                Unknown transformer : how to find a good replacement part ?
                by the_rem
                Hello guys,
                I would like a quite old but still good 800 W ATX PSU to be repaired. The problem was an extremely heavy coil whine coming from the small secondary transfomer on the PCB.
                I desoldered it hoping the references on the upper side would allow me to find a adequate replacement part. Sadly the written references drove me nowhere but to the manufacturer (I-MAG). I sent them a message like a bottle in the see asking them to send me a datasheet of the transformer. And... They responded ! I received a kind of datasheet (see attachment) but my competencies do not allow...
                04-23-2025, 01:48 AM
              • ezenia
                PS4 controller left stick potentiometer replacement issue
                by ezenia
                Not sure if this is the correct section, but I have a PS4 controller that I am trying to fix. It developed stick drift on the left stick and the usual simpler methods did not fix the problem.
                So I went on eBay and ordered some replacement potentiometers. https://www.ebay.co.uk/itm/174967976757 is where I got them from.
                I took the green potentiometers off the replacement sticks and soldered them onto the PCB. Assembled the controller and ran some tests. The drifting was somewhat fixed (not fully in center, but way better than before). However,...
                09-30-2023, 02:19 PM
              • boosti45
                Macbook pro logic board replacement parts quesion
                by boosti45
                i have a 2020 macbook pro 13" A2251 with 820-09149 logic board so i found an issue with chip labeled U6903 according to schem. boardview using flexBV software, so i removed it from the board and the issue im having is that the chip says "07A08FI ELC180​" on top of it but when searching for a replacement chip, i can find tons of identical looking chips that also have "ELC180" printed on them but the first set of digits is never the same so im trying to find out if i need this exact chip with these same numbers as mine and if not which ones are compatible as a replacement?...
                08-21-2024, 05:23 AM
              • r2digital
                klipsch kda-500 amplifier suitable power supply capacitor replacement ?
                by r2digital
                I have a klipsch kda-500 that would turn on and allow me to get into the web management but it was picking up a lot of noise from audio sources so i decided to replace the smd caps on the power supply along with radial one. Some one was in here before me and they basically burned the bottom side of the traces off for the radial cap but i was able to repair it without any real problem. I thought i did a good job sourcing out replacement caps but apparently not and now i can't get the power supply to turn on it just constantly try's to keep turning on. Attached is a picture of the power supply before...
                04-18-2024, 03:50 PM
