Best PCB Etching design for a heat plate?
  • EasyGoing1
    Shock Therapist
    • Sep 2016
    • 977
    I want to use some PCB etch board to make a plate that gets a little warm ... maybe 35C at the most.
    But, I'm unclear as to the best way to go about this in terms of the layout of the copper.
    Would it be better to leave the etch board un etched and just connect the leads on each side like this?
    Or would it be better to etch it so that there is a longer path of copper for the charge to follow, like this?
    sigpic
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Best PCB Etching design for a heat plate?
    This has been done several times before and they all use the wavy track design.
    • EasyGoing1
      Shock Therapist
      • Sep 2016
      • 977
      Is that because etching the board in that configuration causes its resistance to increase from end to end?
      Edit: Actually, I found this article which I should have Googled in the first place.
      sigpic
      • diif
        • Feb 2014
        • 6978
        • England
        This one has a trace calculator. https://hackaday.io/project/181170-reflow-pcb-hotplate
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8701
          Nothing special about PCB heater boards. The trick is where the required placement of the inlet power is - when they are on opposite sides, it's easier; on the same side, it requires some more careful track placement.
          Do note while an unetched board will "work" but the resistance would be so low that you'll heat the PSU more than the board not to mention it's tougher to calculate the wattage, as compared to a serpentine etched board.
            Mounting and Handling Guidelines for TO220 TO220F TO247 Cases / Packages
            The TO220, TO220F and TO247 are the popular packages for power devices because of their versatility and ability to dissipate moderate amounts of heat. This application note describes the basic guidelines for handling power MOSFETs in TO220, TO220 and TO247 packages shown in Figure 1. Please note that only mechanical and soldering guidelines are covered here. Additional precautions are required for isolating high voltage rated devices to meet safety regulations.
            Securing a good thermal interface between...
            10-07-2024, 04:35 AM
          • acedogblast
            by acedogblast
            11-02-2024, 05:13 PM
          • harp
            detecting heat with IR LED receiver
            by harp
            I have some dark IR led, and want to know if it is be situable to detect pure heat (not visable glow ir radiation) in well lighted desk?
            So, if I put hand over it in near distance like few centimeters, that detect rising heat, not covering it from light.
            Something like termal camera, but in one spot, any simple circuit?...
            09-06-2023, 06:03 PM
          • ludovik
            Moto G84 short after heat
            by ludovik
            i was reballing the power manger of a moto g84, after applying heat i tried to power on and it wouldn’t.
            i injected 1.5v to some capacitor that seem in short because both side beep if tested.
            when i inject i feel the cpu burning;
            since the cpu is exactly on the other side of the board, is that possible that the heat from the reballing damaged the cpu? do you know where i can find schematics or what can i do?
            i know this is not enough to explain the situation so if you need any other info ask me please!
            Thank you very much in advance
            11-08-2024, 02:13 PM
          • rictechie
            copper pad in board peel off
            by rictechie
            Hi I'm newbie when it comes to electronics repair. My copper pad where my diode sticks has peeled off what is the most efficient way to make the copper pad stick to the board? epoxy? ink mask? I want to hear your suggestions
            07-20-2024, 11:49 PM
