Recapping LCD PSU, basic question
  • demonfire
    • Jul 2010
    OK, little background:
    I got a free LCD monitor from work (ViewSonic VA902b) because it was broke. When I turn it on, it lights for about a quarter to a half a second then goes black, when lit the image is correct.
    As the image is correct, I believe the image/input board to be good. As it does light, briefly each time I turn it on I know the backlights are good.
    So I suspect it is a bad PSU, and likely bad caps due to the symptoms.
    I opened the case and took it apart to find there are four caps on the PSU that are swollen.
    Here are the questions:
    1. should I go through the trouble of finding the exact same caps (same make/model) or should I go with a better brand? The stocks are Su'scon (read bad things on here about them)
    2. If I don't go for the exact caps, I could use help finding suitable replacements....these don't have all the info on them. There is no tolerance or minimum temp markings.
    3. If I don't go for the exact caps, can I use caps that are the same capacitance but higher voltage? Or will this cause other issues?
    Caps needing replaced:
    1x one side says '1000uF 25v ' the other says 'SC 105C 0601(M)'
    2x one side says '220uF 25v ' the other says 'SC 105C 0601(M)'
    1x one side says '1000uF 10v ' the other says 'SC 105C 0601(M)'
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Recapping LCD PSU, basic question
    1) Use brands like Rubycon, Panasonic, or United Chemicon that have low ESR caps.
    3) You can use higher voltage caps.
    For the above caps, please measure the diameter and height of each cap so they fit when you install the new ones.
    Here is PlainBill's instructions on how to choose caps from Digikey ...
    https://www.badcaps.net/forum/showpo...33&postcount=2
    Recapping may NOT solve your problem, but you must replace the bad caps first. What you are experiencing is what we are calling "two seconds to black".
    --- begin sig file ---
    --- end sig file ---
    • retiredcaps
      • Apr 2010
      • 9271
      I forgot to mention that caps do NOT have to be swollen or bloated to be bad. Sometimes they may be out of tolerance or have high ESR (ohm reading).
      Most on this forum will suggest that you replace ALL the caps regardless especially if they are su'scon.
      Additonally, if 4 caps died, the others are likely near death due to age/heat/usage.
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        Ideally you check specs on old caps then find a good brand that matches of beats those specs.
        Ripple should be the same or higher.
        ESR should be the same or less.
        I gather you are replacing Su'scon SC series by what you said. ??
        Unfortunately that's a dead series. [No data sheets.]
        Given no info I would fail-safe and replace them with...
        - Output filter caps and/or any 470uF or more
        - - - with something comparable to Rubycon ZL or Chemicon KZE [or better]
        - The others
        - - - with something like Panasonic FC or Nichicon PW [or better]
        At a minimum replace all of the same brand that failed from 6.3mm diameter and larger.
        Mann-Made Global Warming.
        - Dr Seuss
        • Agent24
          I see dead caps
          • Oct 2007
          • 5086
          • New Zealand
          Not always. Web Archive can be pretty useful...
          I've found and attached the Su'scon SC series PDFs
          -David VanHorn
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            COOL. - I didn't even think to look there.
            The Su'scon SC
            1000uF 25v ,, Ripple 1600 ,, ESR 0.060
            220uF 25v ,, Ripple 590 ,, ESR 0.180
            1000uF 10v ,, Ripple 1000 ,, ESR 0.075
            Panasonic FC, Nichicon PW, or better are adequate replacements.
            http://industrial.panasonic.com/www-...BA0000CE22.pdf
            http://nichicon-us.com/english/products/pdf/e-pw.pdf
            - Dr Seuss
            • demonfire
              • Jul 2010
              OK, so all the canister (Aluminum Electrolytic) caps are Su'scon, so I might as well replace them all.....Do I need to replace the disk type ones too? I heard they are more stable so I am not sure....not to mention it takes the cap count from 11 to 26.
              So, I am now replacing at least 11 caps, any one-stop shops for all of them which are easy to order from and not too expensive?
              I would need:
              1x 100uF 450V
              1x 1000uF 25V
              2x 1000uF 10V
              3x 220uF 25V
              4x 47uF 25V
              • retiredcaps
                • Apr 2010
                • 9271
                Those are generally okay to leave alone.
                I would need:
                1x 100uF 450V
                1x 1000uF 25V
                2x 1000uF 10V
                3x 220uF 25V
                4x 47uF 25V
                Assuming you are in the USA, many here use digikey.com for quick ship and reliable source of caps.
                The "big" cap which is 100uF 450V rarely goes bad, but you may as well order it.
                After you measure the dimensions of the caps, go back to post #2 and see PlainBill's instructions. He recommends Panasonic FM series of caps. Panasonic FC will work too. And you can mix and match FM and FC if height/diameter are an issue.
                  by momaka
                  03-12-2025, 03:42 PM
                • eryjus
                  by eryjus
                  05-10-2023, 11:21 AM
                • Paxman_Swede
                  by Paxman_Swede
                  Hello!
                  01-14-2025, 09:51 AM
                • captain150
                  by captain150
                  03-16-2025, 07:34 PM
                • Foetuss
                  Gigabyte GA-6OXT :: caps question
                  by Foetuss
                  Good evening
                  I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
                  Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
                  But I was also suprised about the bigger boys, which are 330µF 25V.
                  Could it be they used 25V caps because they were cheaper / available at that time?...
                  02-11-2025, 12:22 PM
