Need advice - hot tweezers under 300 usd
  • madfreak
    • Aug 2012
    • 135
    • Poland
    Hi folks, i really need dvice about hot tweezers for soldering smd
    I need them really bad to speed up the work but those that i like costs a little bit too much :
    JBC CP-2QF
    https://kaisertech.co.uk/jbc-cpd-mic...dering-station
    Maybe someone also has that kind of dilemma and has found something a little bit cheaper ?
    I will be really grateful for a help.
    Or maybe someone is rich enough and want to give me a gift ...i will give you address for the shipment
    Have a great day
    • Jul 2011
    • 6070
    Re: Need advice - hot tweezers under 300 usd
    Do you want something that is micro in size because you can find a large version for probably less money and have different options for the tips
    Thanks for wanting advice for hot tweezers I found some for my soldering station that I like to use a lot but I have to maybe modify it slightly for it to work correctly with my setup
    Look on EBay for some there some different type of these tweezers but I would highly recommend that you buy one that is temperature controlled for best results
    Here is what I just bought from EBay
    https://www.ebay.com/itm/39403986360...53.m2749.l2649
    • Ady2017
      SMD fuse soldering advice please
      by Ady2017
      Hi all. I need to replace an SMD fuse on my camcorder and this is the first time I have had to do any SMD soldering so your advice would be appreciated. Below is a picture of the board that I am working on and I have highlighted the fuse that needs to be replaced. I managed to zoom in to take this picture but the fuse is really tiny and is sandwiched between other components so this is going to be a new milestone for me. I appreciate that I am going to have to buy a new soldering iron if you could advice on what I need please. I was thinking about putting a big soldering iron across the whole...
      11-07-2025, 12:03 PM
    • bql
      In search of advice for flashing bios via efi shell
      by bql
      Hi Badcaps,
      I'm having the same Notebook and problem as in this topic:
      HTML Code:
      https://www.badcaps.net/forum/troubleshooting-hardware-devices-and-electronics-theory/troubleshooting-laptops-tablets-and-mobile-devices/bios-requests-only/3601016-need-bios-for-clevo-pd50pnp
      I'm assuming that flashing the provided bios in this topic would solve my problem.
      The only thing i can boot to is EFI shell
      How do i flash the bios image in the EFI shell ? / Can i use any flash.nsh or is the executable interconnected to the bios image? ( i cannot find any bios related files in the internet...
      11-26-2025, 05:21 PM
    • iam5
      Intermittent USB-C / USB-A issues + Trackpad Freezes — T14s Gen2 (11th-gen Intel) — Seeking Board-Level Advice
      by iam5
      I’m looking for advice on board-level troubleshooting and potential component-level repairs for a Lenovo ThinkPad T14s Gen2 Intel (i7-1185G7) showing multi-domain instability. Hoping someone familiar with this platform (or the related X1 Carbon Gen9/Gen10, X13 Gen2, X1 Nano Gen1/2) can point me toward the right section of the board to inspect, and whether any of the known fixes apply. Symptoms:
      1. Trackpad (CS21 module) intermittently freezes during active use
      • Not tied to lid open/close
      • External USB mouse continues working
      • Sometimes recovers with sleep/wake
      • Looks like
      11-25-2025, 09:29 AM
    • chazzo
      CH341 programmer advice, including jumpers seemingly reversed
      by chazzo
      I’d appreciate some very basic advice on CH341x programmers. I know this topic comes up from time to time, but stuff changes, so I hope a refresh is in order. In particular, I see some unexpected things happening with jumper positions.
      [My plan is to learn to read and write 24CO2 EEPROMs via I2C. The first target is the one in my Uni-T clamp meter, but before tackling that I have some brand-new EEPROMs to practice on.]
      I have two basic Chinese programmers. One is the blue board with a CH341A and two rows of pin headers. To my untrained eye it looks like all the others....
      10-12-2025, 08:15 AM
    • Jidis
      Need T-Con Advice (Vizio P602ui-B3)
      by Jidis
      I made a big-ass mess here of my father's beloved P602, and I'm trying to figure out if I should order a batch of overpriced ribbons or if I'd just be throwing more good money at the bad.
      He woke up recently to a bunch of white bars going down the right side of the screen. From what I'd seen in these places, I figured the T-con board has gone out or has a bad connection. I took the back off and gently poked at the socketed ribbons and sure enough, got the image back. It was mainly the far left ribbon, and it would snap back to stripes if I let off the pressure....
      09-22-2025, 05:10 PM
