My DELL INSPIRON 530 Desktop Computer Won't Turn ON ............?
  • eruptionjoojo
    • Jun 2010
    • 5
    Sry! If i have posted in the wrong Section ...........
    Hello Everyone,
    I have a DELL INSPIRON 530 Desktop(around 3yrs. old) .......... motherboard - Foxconn G33M02 ...... it was working fine till yesterday but after having cleaned the system for dust and all ...... I again powered the system and it just woun't start i.e. even after pressing the power button(on the front side of the system), nothing happens i mean no fans moving,no light of any kind, no nothing. Although the Green LED under the power cable connector turns green (on the back side,Just below the power cable connector) after having attached the power cable to it. For having a look inside i opened the cabinet that found that the Orange LED is light up almost on the top right corner of the motherboard but nothing happens while i press the power button ..... and thus i'm fearing that the motherboard has gone out of order ...........
    In order to troubleshoot the problem i jumped the Green and Black cable ports of the PSU and the fan starting moving ........ so, i'm supposing that the PSU is working fine ...
    I'm also wanting to know how to check the motherboard and if so the individual capacitors and resistors on it ...........and if just in case i'm unable to resolve the issue what options do i have in terms of motherboard(which is similar in technical specifications to my original motherboard), as DELL is charging me a lot more than the price of a new Motherboard .............
    so,kindly suggest me a new motherboard of similar capacity i.e. no of SATA ports,IDE ports,RAM slots etc.which i can buy from a local vendor ........
    My current system configuration are as follows :-
    Intel Pentium Dual Core E2160
    Foxconn G33M02 Motherboard
    300 Watts PSU/SMPS
    SATA DVD RW+/-
    Bluetooth module with 13 in 1 media card reader
    IEEE firewire 1394
    TV tuner card(internal)
    Intel's Onboard LAN
    SATA HDD 160 GB
    Link to the Specification page :-
    http://supportapj.dell.com/support/e....htm#wp1052310
    Any help in this regard would be greatly appreciated ............
    thnxx in advance .............
  • retiredcaps
    • Apr 2010
    • 9271
    Re: My DELL INSPIRON 530 Desktop Computer Won't Turn ON ............?
    I suggest checking all your connections again. It is possible that you knocked something loose during cleaning.
    Reseat all connectors, DRAM, power connectors, etc.
    Double check your fan/heatsink on the CPU.
    --- begin sig file ---
    --- end sig file ---
    • Tomthetech
      • Jun 2010
      • 3
      Check that the 2 jumper wires are pushed in the jumper panel on motherboard (Probably marked PW+ and PW-) from your chassis front panel to motherboard, these go to the front power switch. When these 2 pins on motherboard are shorted pc turns on.
      • yyonline
        • Jul 2009
        • 692
        I've fixed more than a few of these with dead Bestec power supplies. Not the dreaded 12E power supplies, but dead Bestecs nonetheless. I know you said you jumpered it and it powered on, but that often means little in terms of the power supply functioning properly.
        • eruptionjoojo
          • Jun 2010
          • 5
          thnxx a lot for your reply ..........
          but actually i have already reseat everything from HDD to Ram,power cables ..... but of no use ..........
          although i would recheck once as again as you have suggested .......
          • eruptionjoojo
            • Jun 2010
            • 5
            as you suggested i have checked the jumpers and they are in proper position ....... and one thing which i wanted to ask is that you said that the computer starts if the 2 pins i.e. jumpers are short is it like without having to press the power button or after pressing the power button ..... ??
            anyways thnxx again for your reply .........
            • eruptionjoojo
              • Jun 2010
              • 5
              i have already tested SMPS/PSU by replacing it with a new one .....
              if i need to follow some more steps in order to be confirm, kindly suggest me the steps ......
              • eruptionjoojo
                • Jun 2010
                • 5
                Thnxxx to everyone who so ever replied ..............
                and yeah the good news is that my system has started working perfectly again .........
                it all happened while i removed everything off my computer except the motherboard and processor and troubleshooted the Power ON/OFF switch ..... n there i was there was a loose/faulty connection at the terminal of the ON/OFF switch connection .........
                So,while i pressed the port quiet hard and powered the ON/OFF switch, the computer started and there and then my problem got solved .......... although i had previously also reseated the On/OFF switch port earlier but i don't know still may be there was some error earlier ........
                thnxxx again to everyone .............
                • Tomthetech
                  • Jun 2010
                  • 3
                  Glad that you worked it out eruptionjoojo :-)
                  • master3112
                    by master3112
                    07-29-2025, 01:55 PM
                  • sourceaxe
                    Dell Precision 3650 Tower (Desktop motherboard) - Schematic (and board view) request
                    by sourceaxe
                    Does anyone happen to have the schematic (and if available also: the board view) for the Dell Precision 3650 Tower motherboard please?
                    Manufacturer: Dell
                    Model: Precision 3650 Tower
                    Motherboard markings:
                    • IPRKL-RDT REV: A00
                    • D33D66
                    • CN-0NDYHG-PE100-1AM-05SY-A01
                    • P&Q 2134 CM-4 94V-0 E162264
                    Thank you in advance.
                    11-21-2024, 05:35 PM
                    DELL Chromebook Inspiron 7486 Chromebook Specification for Upgrade or Repair
                    This specification for the DELL Chromebook Inspiron 7486 Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 7486 boardview and Inspiron 7486 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                    09-06-2024, 11:50 AM
                    09-06-2024, 11:05 AM
                  • danielgagcia
                    Bios inspiron p69g dell inspiron starlord13 b 152641 stuck in dell logo
                    by danielgagcia
                    Hi i need this bios it stuck in dell logo can help me
                    MB: starlord13 b 152641
                    SN: 5F50ZB2...
                    Yesterday, 05:25 PM
