Do SMD electrolytic caps have a shorter shelf life than aluminium electrolytic caps?
SMD electrolytics
by AdenitzHello,
can I use this cap:
https://www.tme.eu/en/details/ues1h4...tors/nichicon/
Capacitor: electrolytic; bipolar; THT; 47uF; 50V
to replace this capacitor: Electrolytic Radial E 47uF/50V 6.3x11 RM2.5 105°C Jamicon
What exactly I can expect to install bipolar electrolytic cap instead a regular one?
Thanks.-
Channel: General Capacitor Questions & Issues
by ten-dHi all!
I just bought a pair of ADS L810 speakers, which I've heard are some of the best speakers from that time (late 70's) into the early 80's. I was super excited to test them out and hooked them up and I was very underwhelmed by the treble. The treble was awfully muffled. I've been doing some restoration work on 70's stereos and a couple of speakers here and there so I am really just a beginner. I do know that capacitors in speaker crossovers filter out the lows to allow only the highs up to the tweeters and mids. Inductors filter out the highs to allow the lower frequencies to...3 Photos-
by Perry BabinI have a situation where a power supply is commonly abused and the 12v supply caps take a beating. They don't commonly fail but they run hot. I was thinking about going from a liquid electrolytic (Panasonic FC and Nichicon HE) to an organic polymer. The values have been 330uF. I typically use a higher-than-needed voltage to get a lower ESR. The supply is operated from 12v.
If not organic polymer, what would be the caps that could take the most abuse?-
Hi wonderful people. I have a MS-6315 P3 motherboard with very tiny Aluminium electrolytic capacitors. I've made an attempt to identify them from what ive learned so far they might be
Aluminium Electrolytic
G = Series
10 uF
16 = Volt
104 Date code 2001 April? (not really important, but interesting)
Please help to confirm or correct if i am wrong. Thank you
by cloudff7there a risk of this aluminum electrolytic capacitor of electronic device long term storage opening and leaking acid and corroding the PCB board?
- Loading...
