Citroen Contro unit.
  • Eleways
    • Oct 2014
    • 62
    • Italy
    Hi
    I need to replace a control unit on a Citroen C4. So I've got a new one control unit but doesn't work due the immobilizer code.
    I've open both central unit but I've found a Flash Eprom M49F4000 and a 93c56 eeprom.
    I don't know how replace to fix immobilizer problem.
    Anyone can help me?
    Thanks!
    Luca
  • digby1951
    • Jan 2017
    • 36
    • uk
    Re: Citroen Contro unit.
    it will need programming...by main dealer....or buy a DIAGBOX PROGRAMMER from ebay.........but u need to be computer savvy to work the software and know how to use DIAGBOX..........
    ...............if u got a virgin ecu...it needs to be programmed...to get ur immobilizer working
    • Repdata
      • May 2020
      • 67
      • Deutschland
      there is the possibility of cloning
      but this is only suitable for experts
      bring the control device to a company that repairs such devices that should clone the data then everything works again or bring to Citrön for programming if the used ECUs can flash
      • zen
        Drill control unit switch required ,help please
        by zen
        Hi all , it's part of a control unit that operates a drill.
        Striped it down & cleaned contacts but not reliable
        Hoping some one out there in the ethos can help me source one . ( see pictures )...
        05-16-2024, 03:49 AM
      • ngml
        Repair of an LG split AC system indoor unit PCB
        by ngml
        I am trying to repair an LG split AC indoor unit, which does not start and gives a CH05 error code.
        This indicates an error in the communication between the outdoor and the indoor unit.
        The outdoor unit is fine, so the problem is the indoor PCB.
        The indoor unit is an LG PC09SQ NSJ (3SNM09JA2FA), and the PCB has the following type number: EAX35907219-1.2 (see photo1)
        I changed optocouplers ICO1X & ICO2X and the NPN transistor S9013 which drives optocoupler ICO2X (see photo2), but this did not remedy the fault.
        Does anybody have the schematics of this board,...
        02-01-2025, 12:55 PM
      • bauto601
        KDM 480W PSU upgrade succes! (opinions?)
        by bauto601
        Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
        A "nice" YoungYear unit? - Badcaps
        The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
        12-26-2023, 03:05 PM
      • DrDos
        Unit runs but no speaker output kenwood KR-6030
        by DrDos
        I have finished my work. The new lights come on except the one for stereo, I reversed the bulbs to no affect, anyway, the unit powers on, relay clicks. I have no DC voltage in speaker outputs, I also do not have any AC in the speaker outputs. There is some faint crackling in the speaker. This unit cranks up loud so I had the volume on very low. Everything seems to be fine but I can't really check the switch until I can get sound out of the outputs. I was going to do caps for the power supplys and the tone board but thought if it was cranking loud at one time maybe just leave it alone until it...
        09-14-2025, 09:57 PM
      • Yanleb
        LG 60PK550 Logic Control Board EBR63450301
        by Yanleb
        Hi all, I just want to share the repair of my 60PK550-UA TV set.
        The TV set was powering on, just no image. After verification, nothing wrong on the YSus or ZSus boards. Nothing wrong on the main board either.
        But I noticed that the LED was not flashing on the Logic Control Board. This is an EBR63450301. The LED is supposed to flash even with all the flat cables disconnected, with only the power cable attached.
        All the voltages measured at the electrolytic capacitors on the board were good. From top left to bottom right:
        C57: 3.30V
        C61:...
        07-20-2023, 12:38 AM
