Milwaukee Battery Charger M18/M12 Dual battery charger Dead no light during charging
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8339
    Re: Milwaukee Battery Charger M18/M12 Dual battery charger Dead no light during charg
    Originally posted by stj
    i have seen 80v tools
    problem is, it would be cheaper to buy a generator and a 5m extension cable!!!!
    just the fuel is going to cost you an arm and a leg these days.
      • 31246
      or build a hydrogen splitter.
      then watch them tax water!
      the reason there is cooking oil shortages (fake) is because they know we know you can use it in cars
        Milwaukee M18 HD12.0 (12 amp hour battery pack) unbalanced failure charger refusing
        I have two Milwaukee 12 amp hours battery packs that have an issue with battery cells very unbalanced these are probably over 4 years old and been heavily used in the past but now get occasionally used heavily and when I went to use the grinder tool the battery lost battery battery power very quickly so I decided to open it up and found some battery cells voltage from 3.6 to 4.1 no wonder the battery charger was not fully charging them 3 out of 4 LEDs were on meaning that it was only 75% charged
        So I have put them on the battery testing machine to drain each battery cell down to...
        09-04-2022, 04:45 PM
      • serious_electron
        Strange! Acer laptop not powering on but charging the battery (orange light on when charger and battery plugged in).
        by serious_electron
        Hello Everyone!
        I have an Acer Aspire A315-42 laptop. I generally leave it on for long time by closing down its lid (so it enters the sleep mode). Recently, it rained quite heavily in out area. And the humidity and moisture seem to be high. So one late evening, after I opened the lid and turned on the laptop, it did power on as the blue light turned on but after it booted to the desktop screen, just 5-10 seconds after both the screen and blue light went out and laptop shut down (the blue power light turned orange). And after 2-4 seconds that orange light went off and the laptop died.
        06-28-2025, 02:57 PM
      • flat-earther
        how to prevent a connected charger from draining battery when not charging?
        by flat-earther
        I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
        So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
        but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
        So the battery is backfeeding the charger and being drained.
        How can I prevent...
        08-07-2025, 01:04 PM
      • Bowline
        by Bowline
        06-11-2025, 10:13 AM
        Bauer tool battery pack charging with a HERCULES charger modification
        The Bauer power tool battery charger just has to many issues with the charger over heating because I several HERCULES Hercules battery chargers that are 3 amp charge and because they have gone on quite a few times over the years before they came out with the fan cooling battery charger I going to modify one so I can charge Bauer battery packs faster than the crape battery charger that they have
        Here is how this modification is going to be done I taking a 1.5 amp hour battery enclosure and gutting it removing the battery cells and replacing some Ryobi 1.5 amp hour battery pack that...
        05-06-2023, 12:17 PM
