Custom control board for TVs?
  • bobbintb
    • Feb 2014
    • 6
    I've been disassembling a lot of televisions lately and thinking about how they have become more simplified over the years, mostly consisting of a PSU and 1 or 2 other boards, along with the display. I've also seem a project or two where a laptop screen was hooked up to a Raspberry Pi and I started wondering if it would be possible to replace the control board in a TV with a Raspberry Pi. Initially, I'd like to see if the display can be repurposed as a monitor, like with this laptop display:
    https://raspberrypi.stackexchange.co...-laptop-screen
    Maybe in the future, even replace the control board entirely with a Pi Compute Module or something similar. Maybe make a more universal control board eventually. I realize this is no simple feat. Just more of a curiosity at the moment as to how feasible it would be. Thoughts or opinions?
  • Curious.George
    • Nov 2011
    • 2305
    • Unknown
    Re: Custom control board for TVs?
    The electronics inside the TV have to do a few things:
    - receive cable/OTA broadcasts
    - drive speakers with the associated audio
    - decode the "video" into signals appropriate for the LCD panel in use
    - interact with the user (buttons, remote control)
    Beyond that, sets typically include:
    - support various audio-video CODECs
    - support on-line services
    - support updates
    Most (all?) TVs are unsupported in very short order. So, a particular A/V CODEC is likely to not be supported OR crash when invoked with a variant of the original code (which may be buggy!)
    Most on-line services are crippled or gatewayed.
    Whatever the manufacturer had in mind for you as a user is likely not what you, as THE user, want.
    So, treat TVs as giant monitors. Connect one of their "unused" inputs (HDMI, DVI, composite, <whatever>) to the output of a PC and install AND SUPPORT whatever features you wwant on the PC instead of relying on the good graces (and competence!) of the manufacturer.
    [This is a great "rescue" for TVs that are a year or two old and no longer "current"; you can always update the software on the PC long after the TV vendor has given up on the TV itself!]
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
    • m1ch43lzm
      by m1ch43lzm
      05-12-2025, 08:37 PM
    • Yanleb
      LG 60PK550 Logic Control Board EBR63450301
      by Yanleb
      Hi all, I just want to share the repair of my 60PK550-UA TV set.
      The TV set was powering on, just no image. After verification, nothing wrong on the YSus or ZSus boards. Nothing wrong on the main board either.
      But I noticed that the LED was not flashing on the Logic Control Board. This is an EBR63450301. The LED is supposed to flash even with all the flat cables disconnected, with only the power cable attached.
      All the voltages measured at the electrolytic capacitors on the board were good. From top left to bottom right:
      C57: 3.30V
      C61:...
      07-20-2023, 12:38 AM
    • howardc64
      by howardc64
      07-24-2025, 05:17 PM
      Linear Garage Door Opener Control board took a crap install a new control board back normal
      I have been having issues with this garage door opener for a while first the range of the remote was a lot less and sometimes it would start to go down and stop for no reason that I could find and would every once in awhile to start with then it started going more frequently until last Saturday when I opened the garage door it refused to close so I cranked up force all the way maximum limit this did not work also the sensor on one side that has a green and red lights that are supposed to be on when the door is open and there are no obstacles in the way on the original board the only light that...
      02-08-2025, 06:52 AM
