MAC power supply Delta FS8001
  • karkera
    • Jan 2012
    • 5
    • INDIA
    Have a DELTA PSU, FS 8001, the problem is when its put on standalone and PG signal provided by shorting the connector pin, there is still no +12V available, checked the internal PCB boards, MOSFET FDP04N08 seems to be leaky trying to replace all the 4 of them...Does anyone have the schematics of the same would be grateful for help...
    With regards to all...Karkera
  • PeteS in CA
    • Aug 2005
    • 3583
    • USA, Unsure of Planet
    Re: MAC power supply Delta FS8001
    FS8001 seems to be an Acbel model number, not Delta. Having 20 years ago worked for Delta and more recently worked with some of their modern products, I can say with certainty that "FS8001" is nothing like the Delta Products model number format.
    PeteS in CA
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
      03-31-2024, 02:12 PM
      07-01-2024, 06:34 AM
    • dragon3x
      >>> Troubleshooting Delta Power MAX 500ATX ATX power supply
      by dragon3x
      Hi, this is for troubleshooting and, hopefully, repairing a Delta Power psu
      that is still quite new, as it worked OK for some months until it failed.
      At the time I was not into power supply electronics; it was put
      aside and a new power supply installed inside the computer. Also at the time
      power supplies were half the price of today's.
      On the PCB there are a D339 and 7500B chips.
      I have found that schematics with these 2 chips (see included file).
      Does it represent the actual circuit of the MAX-500ATX, I cannot tell.
      Some measurements,...
      06-05-2024, 03:34 PM
    • JimBanville
      Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
      by JimBanville
      The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
      I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
      09-13-2023, 07:21 AM
