just had a thought and wondered if my 100w iron would heat an as15 ic enough to remove it ? the bloody thing is surrounded by tiny components that i would rather stay put .
maybe a job for my 100w iron ?
Tags: None
Re: maybe a job for my 100w iron ?
think i will try on an old board if i can find one . the iron has a large tip .i use it for repairing alternators and starter motors .Comment
It might be that you do not have the right tip for your hot air gun
For what I use mine for is removing IGBT module pins from a circuit board I use the smallest round tube at maximum air flow to do this job so I do not trae off traces on either side of the board with a Desoldering Gun
( and other two sided boards with ground planes )
Try putting foil around everything that is not suppose to be removed
One note to this is a pain in a** to rework this type of application boards
One other note when using very small tip opening you have to have the air flow higher otherwise you might burn out the elementLast edited by sam_sam_sam; 07-12-2020, 07:20 AM.Comment
It's tough because you have to heat up all pins on all four sides. If you heat up only one or two edges, total waste of time.
Another approach I have used is cut the IC's pins off with an Exacto knife. Not too hard to trash the pcb. Then I use solder wick to clean up the pin fragments and clean off the pads.
The small nozzle is bad on my 858D, it's pretty much choked off so much the thermocouple doesn't get enough hot air inside. During warm up it massively overshoots and I can smell burnt plastic, so I first warm it up with a bigger nozzle. The cold heater ceramic seems to keep the thermocouple cold longer than the air is hot.Comment
2.5 ..mmm will have to go look to see the graduation . and the nozzlesComment
ok just tried another board . similar pinned chip but a bit bigger . carried on until my back was hurting ,maybe 5 mins . no melted solder .could burn my finger on the ic . oh the airflow goes to number 8 .Comment
well i got the bugger off with heat gun but had to set at 400 . lifted 2 traces but should be ok . was impatient and started lifting it before it was ready ..my back hurts after a few minutes .Comment
well i didn't even plug in my big iron and the job is done . had to solder the chip twice because it wasn't right first time . i did my old trick of lightly flooding the pins then using the solder sucker to remove the excess . pic was washed out looking so did a picture reset and looking good now .just needs tweaking when i get a remote for it .Comment
not had much luck with hot air as yet . plus i would like to avoid disturbing the minuscule sized components surrounding the ic .Comment
This specification for the Acer Chromebook Acer Chromebook Spin 713 CP713-3W - (Intel Core i3-1115G4, 8GB, 256GB SSD, 13.5 inch QHD 3:2 Touchscreen Display, Google Chrome OS, Iron) Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Chromebook Spin 713 CP713-3W - (Intel Core i3-1115G4, 8GB, 256GB SSD, 13.5 inch QHD 3:2 Touchscreen Display, Google Chrome OS, Iron) boardview and Acer Chromebook Spin 713 CP713-3W - (Intel Core i3-1115G4, 8GB, 256GB SSD, 13.5 inch QHD 3:2 Touchscreen...09-07-2024, 03:10 AM
This specification for the Acer Chromebook Acer Chromebook 514 CB514-1W - (Intel Core i3-1115G4, 8GB, 128GB SSD, 14 inch Full HD Display, Google Chrome OS, Iron) Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Chromebook 514 CB514-1W - (Intel Core i3-1115G4, 8GB, 128GB SSD, 14 inch Full HD Display, Google Chrome OS, Iron) boardview and Acer Chromebook 514 CB514-1W - (Intel Core i3-1115G4, 8GB, 128GB SSD, 14 inch Full HD Display, Google Chrome OS, Iron) schematic. Our users...09-07-2024, 01:30 AM
This specification for the Acer Swift Iron, Intel Core i5-11300H, 8 GB, 1024GB PCIe NVMe SSD, FHD, IPS Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Iron, Intel Core i5-11300H, 8 GB, 1024GB PCIe NVMe SSD, FHD, IPS boardview and Iron, Intel Core i5-11300H, 8 GB, 1024GB PCIe NVMe SSD, FHD, IPS schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional...09-07-2024, 01:00 AM
This specification for the Acer Swift Iron, Intel Core i7-11300H, 8 GB, 1024GB PCIe NVMe SSD, FHD, IPS Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Iron, Intel Core i7-11300H, 8 GB, 1024GB PCIe NVMe SSD, FHD, IPS boardview and Iron, Intel Core i7-11300H, 8 GB, 1024GB PCIe NVMe SSD, FHD, IPS schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional...09-07-2024, 01:00 AM
This specification for the Acer Chromebook Intel Core i5-1135G7, 8GB, 256GB SSD, 13.5 inch QHD 3:2 Touchscreen Display, Google Chrome OS, Iron Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Intel Core i5-1135G7, 8GB, 256GB SSD, 13.5 inch QHD 3:2 Touchscreen Display, Google Chrome OS, Iron boardview and Intel Core i5-1135G7, 8GB, 256GB SSD, 13.5 inch QHD 3:2 Touchscreen Display, Google Chrome OS, Iron schematic. Our users have donated over 1 million documents which are...09-07-2024, 01:00 AM
- Loading...
