Help from pot tweakers needed!
    I'm working on a small electronic project, where I want to deliver 1-~90 mA using a 9 V battery. To do this, I have chosen a linear 10k pot. My problem is, since this pot is linear, that the first 90% of turning the knob, hardly does anything, and the last 10% the current jumps up to 87 mA or so.
    Since finding a reverse logarithmic pot (which I believe is what I actually would need), for all in this range of specs, is extremely difficult, I've been searching the internet for possible ways to tweak my pot to be a little less linear, and found a couple of pages where this is explained. I've tried to connect a resistor parallel to the pot, achieving some small changes, but not quite the one I want... Now I would like to hear if anyone here has experience/knowledge to help me out...
    Problem: I have 9V, 90 mA regulated, and want to be able to control this current steadily rising from ca 1 - 90 mA.
    Solution: ?
    Re: Help from pot tweakers needed!
    use a 1k pot, linear.
    it's pretty easy to understand that your minimum desired current determines the maximum resistance.
    since U=RxI, 1000 ohms give you 9/1000 amps or 0.9mA. (that's why nothing happens in the first 90% of your 10k pot until you hit 1k).
    add a series resistor for the maximum current limit. the same law gives you a value of 100 ohms for 90mA.
    "Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin slitting throats." - H.L. Mencken
      Better check your calculator batteries. 1K and a 9 volt battery will give 9 ma, not .9 ma. Actually, since you are suggesting a total resistance of 1.1K, the current will be 8.2 ma
      PlainBill
        9v @ 0.001a => 9 kohms [9000 ohms]
        9v @ 0.090a => 100 ohms
        A 10k linear pot is about perfect but the behavior sounds like your pot isn't linear.
        Put a 100 kohm resistor in parallel with the pot.
        That will make it's max 9090 ohms and flatten the response curve over the pots whole range.
        Mann-Made Global Warming.
        - Dr Seuss
          Nuther thought.
          You need a range of at least 100 ohm to 9 kohm to get what you want.
          The low end on your pot may not be zero.
          It's range may be something like 5k to 10k in which case you need a different pot or to do magic tricks with resistors.
          - Dr Seuss
            Or you could try this circuit. You might even be able to get a free sample.
            PlainBill
              Well that's what I also thought at first, but when you think it over, a linear pot means you have 5k in the middle, resulting in 9v/5000Ohm = 0,0018 = 1,8 mA. At 10k I would have 9/10000 = 0,9 mA. This is very logical once you get your mind clear, which took me quite some time. What I believe I would need is the behaviour of a reversed logarithmic pot.
              Will it really? Hmm... Tried, after reading some guides on how to tweak pots with external resistors, to put 300 Ohm - 2.2 k in parallel with the pot. This changed the behaviour a little bit, but mostly resulted in raising the current at its lowest point to ~10 mA. This would not be a problem if I would have gotten the wanted slope between 10-90 mA, but I didn't.
              Can you explain why the 100k resistor would change the behaviour in a better way? (would love to just put one there and try it, but I don't have that many different resistors in stock, will have to go buy)
              Thanx for your time and efforts.
                PlainBill
                Hm, well, thanx for the idea, but I believe this solution is a little more than I would like to invest into this project as far as parts and time goes. My solution also doesn't have to be that accurate, so if there is a easier solution, I will go for that.
                  >> a linear pot means you have 5k in the middle <<
                  No, not all linear pots are created equal and I dunno what you have.
                  At first you said you wanted 1 mA at the low end and now you say 10 mA ???
                  My calculator has the night off. - Play with this:
                  http://www.1728.com/resistrs.htm
                  Check:
                  pot[highest value] + added resistor.
                  pot[lowest value] + added resistor.
                  Then calculate both currents.
                  - Dr Seuss
                    Hmm, really? I thought that was the definition of linear...?
                    No no no, I would like to have 1 mA, but 10 mA would also do, if that would mean I could get a linear slope between the lowest and highest current.
                    Check:
                    Very nice tool, will save that page. Don't know exactly how to count, have to think it over.
                      Linear just means the amount of adjustment [movement] in the dial or slide paddle is 1-to-1 to the change in resistance for the whole scale.
                      They can built them for whatever they want for min-max values.
                      If non-linear they can put the 'fast' end at the high or low end.
                      Lets say it's a 100k pot with a range of 0-100k and a dial with 100 'clicks' rotation.
                      Linear.
                      10 Clicks from 1-10 = 10k change
                      10 Clicks from 90-100 = 10k change
                      ... 1-1 response over the whole range
                      Non-linear
                      10 Clicks from 1-10 = 1k change
                      10 Clicks from 90-100 = 30k change
                      ... response curve is similar to a logarithmic curve.
                      - Dr Seuss
                        Linear.
                        Non-linear
                        This is what I meant, a linear pot with 0 - 100k will have 50k in the middle since it is...linear.
