Usb to i2c eeprom programmer ??
  • m3mo3y
    • 31
    • Sweden
    Hello guys ..
    For 3 days i was looking online about how to read and write eeproms using i2c protocol, like you have a device has an eeprom within an IC and the board has i2c pins (SDA, SCL) and I'm trying to read and write this eeprom . But I failed to find a way!!! All what i found is you have to write your own software !!
    I just need to select an address and read or write !! That's it
    I have ch341a programmer i was able to dump the eeprom but it was not perfect i couldn't select any address !! Just read every device on the bus !!!
    Anyone know any usb to i2c adapter or how can use the ch341a to do what i need !
    Thanks guys. 😘😘
    • 31284
    Re: Usb to i2c eeprom programmer ??
    so you want to read the chip in-circuit?
    maybe alternate software can choose the address.
    https://sourceforge.net/projects/ch341eepromtool/
    https://www.onetransistor.eu/2018/11...n-windows.html
    • m3mo3y
      • 31
      • Sweden
      Thanks man for your reply ...
      The second program (AsProgrammer) i tried it, but it didn't work for me i couldn't get i2c option to work
      I didn't try the first one i will give it a shot ..
      Thanks bro for helping❤️
      • chazzo
        CH341 programmer advice, including jumpers seemingly reversed
        by chazzo
        I’d appreciate some very basic advice on CH341x programmers. I know this topic comes up from time to time, but stuff changes, so I hope a refresh is in order. In particular, I see some unexpected things happening with jumper positions.
        [My plan is to learn to read and write 24CO2 EEPROMs via I2C. The first target is the one in my Uni-T clamp meter, but before tackling that I have some brand-new EEPROMs to practice on.]
        I have two basic Chinese programmers. One is the blue board with a CH341A and two rows of pin headers. To my untrained eye it looks like all the others....
        10-12-2025, 08:15 AM
      • JoWed
        Problems with reflashing BIOS Chip on omen by hp laptop 17 an104ng
        by JoWed
        Hello Community,
        I recently tried to change the Batterie on my Omen by HP Laptop 17 an104ng and after putting in the new batterie ([Batterie Link](https://www.amazon.de/7xinbox-17-AN0...&keywords=16%2...
        07-01-2025, 09:32 AM
      • what_1282105
        Thinkpad t480s, completely dead after BIOS flash using CH341A programmer
        by what_1282105
        Following this guide (https://www.reddit.com/r/thinkpad/co...g_and_flashing) i re-flashed my t480s BIOS using an external (CH341A) programmer. The flash didnt work, so i reverted back to my BIOS backup successfully. The BIOS in the chip and the BIOS backup file are identical according to windows' file compare. The revert, however, didnt work: the only thing the computer does is flash the power button 3 times when AC power is connected. I've tried unplugging the CMOS battery, holding the reset button and holding down the power button- no signs of life....
        02-14-2025, 07:27 PM
        by SMDFlea
        Bad...
        09-02-2021, 04:40 PM
      • ahmedtou
        HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
        by ahmedtou
        help me please
        I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
        When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
        I will share all the details with you, including the disc information.
        Code:
        HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
        Current Profile: BD-R
        Disc Information:
        Status: Empty
        State of Last Session: Empty
        Erasable: No
        Free Sectors: 12,219,392
        Free Space: 25,025,314,816 bytes
        Free Time: 2715:27:17 (MM:SS:FF)
        Next
        08-27-2025, 08:49 AM
