Capacitors voltage question...
  • Keeper
    • Jan 2008
    Hello!
    I have a DVR Motherboard which has 2x 1000uF,10v caps which have blown, and i've decided to recap it. So, i called a company which sells capacitors and they said to me that they didn't had 1000uF, 10V capacitors - only 1000uF, 16v caps - to which they told me that the overvoltage of this caps (1000uF,16v) wouldn't be a problem...
    What i ask you is: Is this true ? can i put higher voltage caps (with the same farads) on motherboards which have lower rated voltage caps?!? What can happen in short/long term ? - putting it simple: which are the implications of doing this?
    Thank you for your help!
    Keeper
  • Leopard
    • Mar 2008
    • 109
    • Finland
    Re: Capacitors voltage question...
    Yes, you can put capacitors rated for higher voltage, the voltage marking on caps just indicates at how high voltage the capacitor can operate. Caps rated for higher voltage are usually larger in diameter, so make sure you have enough space there.
    For motherboard application you need capacitors with low ESR, be sure to get quality ones.
    • Keeper
      • Jan 2008
      Okey Leopard, Thank you!
      Regards,
      Keeper
      • Perry Babin
        Operating caps well below rated voltage
        by Perry Babin
        I think this has been answered but I couldn't find the thread.
        Someone asked me if it would harm a capacitor (10F [not a typo], 24v) if it was operated on nothing more than 12v.
        So, I ask... Does it change any of the capacitor's characteristics/parameters/? in any way if it is never operated near rated voltage?
        If operated for years at 1/2 rated voltage, does it accept full rated voltage like it would if it had always been operated at the higher voltage?
        Or would it require reforming?
        05-23-2024, 05:43 PM
      • quickname
        Cyberpower 1500AVR UPS repair
        by quickname
        I'd like to start out by thanking this forum for providing the info to be able to repair my 15 year old CP1500AVRLCD UPS. Here is all the info I gathered during my trouble-shooting and re-capping.
        I decided to verify that the batteries were...
        11-12-2023, 09:57 AM
      • Green Probe
        Recapping a Denon AVR X6400h SMPS
        by Green Probe
        (TLDR: It was capacitor C6519 [Koshin KZH 50V22uF] and C6515 [Koshin KZH 25V47uF] on the power supply. I have questions at the end)
        Disclaimer: I'm an amateur hobbyist and will get things wrong.
        Always use caution when working around mains power and high voltage capacitors!
        Hey guys, I'm repairing a Denon AVR X6400h for my brother. It quit powering on after a power outage. It acted like this last time there was an outage, but after letting it sit overnight it started working again for a few years. This time letting it sit did not bring it back.
        SYMPTOMS:
        -No display...
        07-18-2025, 03:36 PM
      • Phil289
        Audio rated caps - is it ok to use ‘audio’ rated caps on a non audio device
        by Phil289
        Hi
        Just a quick question - is it ok to use ‘audio' rated caps on a non audio device.
        Is there any reasons why they shouldn't be used?
        I'm just trying to find some good quality caps on ebay for a small repair and I've noticed there are alot of audo rated caps in the size i need but not so many non audio rated.
        If I can't find any Panasonic what would be any other good makes to consider?
        Thanks 🙂
        09-25-2022, 03:02 PM
      • SwedishDiesel
        Dell Optiplex GX260 - Advice Needed for Polymodding Motherboard
        by SwedishDiesel
        Howdy folks,
        I have an Optiplex GX260 that blew a couple of those troublesome Nichicon HM series (ultra low ESR) electrolytic capacitors. Because said caps are obsolete, they are pretty much impossible to find on the market; I did find a listing for some but I believe they are counterfeit. I feel the easiest thing to do would be to replace all the blown caps with polymer ones. I am by no means an expert in electronics, and I've found a fair bit of conflicting information, so any guidance or confirmation would be greatly appreciated. While from a practical standpoint it's not worth...
        10-30-2021, 12:47 AM
