Center Pin Polarity Check?
+ More Options
Posts
  • mariushm
    • May 2011
    • 3799
    Re: Center Pin Polarity Check?
    Originally posted by vestaviascott
    That would certainly make it brain dead simple, but there is no such diagram to be found. That's why I'm asking how to test the polarity without that diagram to guide me.
    Grab a multimeter. Put it in continuity mode. Put one probe on the negative in the battery compartment and touch the outside of the barrel connector with your other probe. if there's continuity, you know the outside is negative and center is positive.
    If needed, plug one of your jacks into the connector to make it easier to connect the probe of your multimeter to the exterior of the connector of your machine.
    The machine has a barrel type connector. How would I connect a USB charger to it?
    A usb cable is cheap, often less than 1$. plug cable in the usb charger, cut the connector on the other end. you'll have 2 or 4 wires inside, ground (black usually), voltage (red usually) and optionally data wires (usually white and green)
    worse case scenario , you can grab a couple of D batteries and either solder or tape (with some good electrical tape) the positive and negative wires, each to one battery .. then put the batteries in the compartment ....
    your battery compartment is most likely this :
    negative inside device --- [ - +] [ - +] [ - +] [ - +] --- positive inside device
    so you only need to have 2 batteries inside or something that would press the wires onto the terminals, one on each edge of the compartment, with the wires connected to the metal that's touching the terminals inside the compartment.
    the top lid just makes the connections between the batteries, and if you connect wires directly you don't care about it, no need to have 4 batteries.
    apologies for the horrible typing, my main keyboard just died on me today and this is a horrible 3$ keyboard with crappy keys, have to punch the keys to work, so i may miss some letters and can't be bothered with uppercase.
    • vestaviascott
      • Aug 2018
      • 100
      Exactly what I was looking for. Got it. Thanks.
      Thanks for the explanation and covering all points. It's really appreciated. I'll do the tests as you indicate.
      • vestaviascott
        • Aug 2018
        • 100
        Originally posted by budm
        I would do the research online to find out what the original power supply is capable of and it should also have polarity printed on the power supply itself. BTW, some of them may use AC output instead of DC, that is why you need to do research first.
        BTW, the center pin of typical 5.5 mm barrel may be 2.1mm or 2.5 mm so you need to verify that also since 2.5mm of the adapter will fit into 2.1mm pin but it will not make proper contact.
        Thanks, especially for the 2.1mm vs 2.5mm tip. Tightest fit that works?
        About the first part of your response, I'm finding, when I search for power adapters for these machines, the output specs on the adapter pics are ALWAYS blurred out or removed, likely to prevent you from sourcing a generic adapter matched to volts and amps for the machine.
        • vestaviascott
          • Aug 2018
          • 100
          It was damn tedious getting those wires to stick with electrical tape, especially as I pushed them into their sockets on the console, but she lit up! The fan and the resistance motor appear to work as expected too.
          • vestaviascott
            • Aug 2018
            • 100
            I really appreciate your suggestion here.
            But, I'm not clear on how you are suggesting that I connect the cut USB cable to the elliptical's DC input adapter. Its a barrel type AC/DC adapter female receptacle. How would I insert a cut USB cable into it? Perhaps you are suggesting that I splice a properly sized adapter plug into the cut USB cable and then plug that into the elliptical?
            That would allow me to use the universal power supply I have since it will output 6v and 2.1amps to the USB. And if the USB cable's output end is a properly sized pin (rather than a USB socket end), it should work in concept.
            However, if you are suggesting I use a USB charger (like the white iPhone chargers), rather than my adjustable univeral adapter (that I can dial up a specific output voltage matched to my machine's requirements) How do I know that the voltage and amperage are correct (need to be 6 volts 2 amps)
              So what is the model number of this elliptical machine?
              • vestaviascott
                • Aug 2018
                • 100
                Its a Pro-Form 850 Elliptical Model # PFEL5105.1
                I've just ordered a replacement battery cover for it but I'm not going to order an AC adapter for it since the batteries with the cover are fine for operation. But being able to use my adjustable power adapter until the battery cover gets here would be nice if I can figure that out with the 2amp USB splice.
                SearsPartsDirect gave me free shipping on the cover and the grand total was less than $8 bucks. Hopefully it gets here sooner than the Sept 20 estimated arrival on the order confirmation!
                • vestaviascott
                  • Aug 2018
                  • 100
                  BTW, here's but one example of how these replacement adapters output specs get doctored out of sales page photos:
                    At least it shows center pin is +.
                    • vestaviascott
                      • Aug 2018
                      • 100
                      True on this one, most don't even show that - or they are so low res you can't make out if its a + or -. This one's not for the 850 elliptical however.
                      • acedogblast
                        [Marantz SR5012] Center channel keeps going into ASO/Overcurrent protection.
                        by acedogblast
                        First off I would like to thank this community as it has provided me with great information that has helped me greatly on my repair for this Marantz SR5012 AV receiver. I am creating this new thread as the other 2 that I have created here has had their original question/problem solved and I plan that this is the final thread on my repair. Please note that this is my first time repairing audio amplifiers so I may not be aware of common issues and things to know.
                        Lets start at what I have done so far. Random speaker popping on all channels is fixed by replacing the 2 large filter...
                        03-01-2023, 08:24 PM
                      • dreico33
                        TL866 II Plus Check ID Error on various IC
                        by dreico33
                        Hellow guys , i really need your help here.
                        Lately i have a problem with My TL 866 II Plus programmer, and to be more specific many times on various IC ( Winbond, Gigadevice Mx) i get Check ID Error while i am trying to read the IC. Has already been detected without any kind of problem, but the only to read them is to uncheck every time the "Check ID " option. After that i can read it erase it and re-program it only to get another error at then end saying that can not verify the programing went well so i have program failed. So i am trying to find out what is going on? I...
                        11-04-2024, 03:13 PM
                      • hasel17
                        CH341a can erase and read but can't write and blank check
                        by hasel17
                        So I am trying to repair broken thunderbolt FW on X1 Yoga Gen 2. The EEPROM chip is WINBOND 25Q80DVNIG. I already do a back-up and erase. But when I try to wrote new FW, it was successfull, but when I tried to read it, it still blank. when I try to do a blank check, it gave me instant error in address 0. I already tried two CH341A, already did the 3.3v fix mod, using AsProgrammer, NeoProgrammer, Colibri, and CH341A 1.29. But the problem still occurred. What I did wrong here? Can anyone help me? Thanks in advance. Here is the log in Colibri :
                        Code:
                        Checking for blank...
                        (Press
                        10-26-2023, 06:20 AM
                      • Daniel Larsson
                        Marantz SR7500 burning output transistors - so far 2 channels are gone. Help!
                        by Daniel Larsson
                        Will start with the question and the full story follows below.
                        Can someone please let me know what voltage I should see per pin on the protection circut IC81, TA7317P?
                        My voltages per pin with the IC removed, only measuring on the soldering pads now, are:
                        1 -0.39
                        2 0.0
                        3 0.0
                        4 0.0
                        5 -12.5
                        6 11.94
                        7 0.0
                        8 11.74
                        9 11.74
                        The full story is that my Marantz SR7500 shut down a couple of days ago stating "CHECK POW5".
                        I checked the service manual to find out that the...
                        05-30-2025, 11:39 AM
                      • Geeker007
                        9th Gen Dell Optiplex Micro PC motherboard repair: Short Circuit?
                        by Geeker007
                        Hi All, I have a 9th Gen Dell Optiplex micro PC motherboard which doesn't power on. When I connect the motherboard with power adapter, it goes into safe mode and turns off. So from info I have gathered online, it looks like there is a short circuit on the motherboard. So can you guys help me with figuring out the issue?
                        I am new to electronics repair, so my queries could be naive but I am ready to learn.
                        So I have a multimeter and a solder with me. But I can try to get a variable voltage power supply with a thermal camera as well. From what I seen online, best way is...
                        01-28-2025, 03:31 PM
