Transformer Ringback testers
+ More Options
Posts
  • johnfin
    • Oct 2017
    • 115
    • united states of america
    When I use my flyback tester on a power transformer I can only get a reading on the primary side on all transformers I know that are good. Wonder if thats typical. So, is a good test of a transformer when you put a square wave thru it with a function generator and it comes out on the secondary side?
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: Transformer Ringback testers
    Putting in a square wave may burn the Primary.
    • johnfin
      • Oct 2017
      • 115
      I thought SMPS use a high freq. pulse on the primary side. How would it blow the transformer out?
        • 31044
        it wont, the current on a "ringer" is limited to about 30ma usually.
        the reason you cant test the secondary is because it does not have enough windings to create an "echo"
        is yours based on the dick smith design, or something else??
        • johnfin
          • Oct 2017
          • 115
          I was going to build that one but then I realized I could use my function generator and oscilloscope. They basically do the same thing, right?
            • 31044
            creating a pulse and counting the reflections - that;s about it.
            • redwire
              • 3910
              Mains power transformers are steel-core and flyback transformers are ferrite-core with air-gap. The two core materials have different properties, mainly ringing frequency. Very good detailed article about testing them here:
              https://www.repairfaq.org/sam/flytest.htm
              The Anatek Blue Flyback Tester applies a narrow pulse (guess 15mA) and then counts rings.
                • 31044
                that's a licensed design, the schems are available to build your own.
                • redwire
                  • 3910
                  That kit manual has the schematics, might be worth picking one up.
                  Few of us are testing TV flyback transformers nowadays.
                  I remember this thread, that shorted standby transformer could have been found sooner: https://www.badcaps.net/forum/showth...t=59625&page=6
                  Maybe these transformer testers need to make a comeback?
                  • eccerr0r
                    Solder Sloth
                    • Nov 2012
                    • 8701
                    I wonder if the AVR in avrtester is fast and sensitive enough to be a ring tester if you hook up a capacitor in parallel to an inductor before testing...
                    And I have a Sencore and it ruled out the "flyback" when I was debugging my scope...
                      • 31044
                      the AVR project doesnt really have enough memory left for more tricks!
                      • johnfin
                        • Oct 2017
                        • 115
                        The point is, most of us with scopes have a function generator, mine is a $5 home brew, so with those tools is a ringtester a waste of money?
                          • 31044
                          maybe,
                          parts cost is about the same as a beer.
                          it depends if you want a compact device you can throw in the drawer.
                          • eccerr0r
                            Solder Sloth
                            • Nov 2012
                            • 8701
                            Can you really use the function generator, I'd think you'd need an open collector/open drain pulse/square generator to do this test because the impedance of the function generator would also damp out the rings...
                            • johnfin
                              • Oct 2017
                              • 115
                              https://youtu.be/x6mTnWbbmPg
                              • redwire
                                • 3910
                                Like a guitar string, you pluck it and listen to the note decay.
                                I don't think you can use a signal generator - they are push-pull output and never unload the coil to let it ring and decay. Unless you add a series diode to the sig gen output.
                                A narrow pulse from open-collector transistor is what I see used. Same used in that youtube video but he doesn't mention it.
                                The question of in-circuit testing... for a SMPS, if you excite the core below where the output rectifier diodes turn on, should be able to see the ringing.
                                  HP Pavilion Wave Pavilion Wave Desktop - 600-a030na Pavilion Wave i3-6100T Specification for Upgrade or Repair
                                  This specification for the HP Pavilion Wave Pavilion Wave Desktop - 600-a030na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Wave Pavilion Wave Desktop - 600-a030na boardview and Pavilion Wave Pavilion Wave Desktop - 600-a030na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                                  09-12-2024, 03:44 PM
                                  HP Pavilion Wave Pavilion Wave Desktop - 600-a103na Pavilion Wave i3-7100T Specification for Upgrade or Repair
                                  This specification for the HP Pavilion Wave Pavilion Wave Desktop - 600-a103na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Wave Pavilion Wave Desktop - 600-a103na boardview and Pavilion Wave Pavilion Wave Desktop - 600-a103na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                                  09-12-2024, 02:00 PM
                                  HP Pavilion Wave 600-a055cn Pavilion Wave i5-6500T Specification for Upgrade or Repair
                                  This specification for the HP Pavilion Wave 600-a055cn can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Wave 600-a055cn boardview and Pavilion Wave 600-a055cn schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                  HP Pavilion Wave 600-a102ng Pavilion Wave i3-7100T Specification for Upgrade or Repair
                                  This specification for the HP Pavilion Wave 600-a102ng can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Wave 600-a102ng boardview and Pavilion Wave 600-a102ng schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                • ohren
                                  Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
                                  by ohren
                                  Hello!
                                  I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
                                  Measured voltages with no load:
                                  After rectifier diodes
                                  12V: 6.17 V
                                  5V: 5.67 V
                                  Secondary transformer pins AC measurement (really don't know if this says anything)
                                  12V: 2-2.5 V
                                  5V: 1.04 V
                                  I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,...
                                  03-18-2023, 10:33 AM
