Help choosing replacement SMD transistor
  • RickyZA
    • Jan 2017
    • 33
    • South-Africa
    Hi there everyone,
    Im looking for a replacement transistor for my TV's logic board, unfortunately i had a newbie slip and shorted out the Pwr_On to the 20v rail with the mainboard connected, not very clever at all i know. Here is the damage.
    Transistor Close up
    Original Transistor Datasheet : RT1P141C Marked P1
    Main Board Schematic for transistor Reference: Service Manual / Main board Schematic Not the exact same model but im pretty sure they use the same transistors marked P1 which is the RT1P141C.
    My other question is could i still be lucky enough that this hasnt damaged anything else ? After the component got burnt i could test continuity on all 3 legs...
    I have another thread which i specifically made for diagnosing my power supply on my LG set, i hope creating this thread shouldnt be a problem as its more aimed toward finding a replacement than diagnosing the mainboard. im quite desperate for help sourcing this replacement transistor as i might even have to import it.
    I guess choosing a replacement with small differences shouldnt end up being a problem although this also depends on how close to the limits this transistor was being used in the first place ? Please correct me if im wrong.
    If anybody has detail into what specifications are utmost important in choosing a replacement transistor id appreciate it. Thank you all !
  • RickyZA
    • Jan 2017
    • 33
    • South-Africa
    Re: Help choosing replacement SMD transistor
    So ive taken a look at this electronic reference site.
    Replacement seems to be the DDTA114ECA-7-F
    Datasheet : Here
    Most of the specifications seem to be in check although i cannot compare some specifications as the datasheets are slightly different, could anybody confirm if this would be a suitable replacement ? Thanks !
    • RickyZA
      • Jan 2017
      • 33
      • South-Africa
      Found something even closer
      PDTA114E
      My worry is the peak current is only -100ma continous and peak on both replacements, input voltage seems to be -40 on the RT1P141C it seems the PDTA is +40 input ? Seems the DDTA can handle +10 to - 40V though.
        That will be fine, the current through that switched Transistor is very very low, and we are dealing with only 3.5V. The 114 has lower Beta, but for this application it should be fine.
        • RickyZA
          • Jan 2017
          • 33
          • South-Africa
          Thanks budm, ive ordered 10 of them today, lets see what happens ! Peace
          • Haaheim
            Bias matching replacement transistor - Parasound 2250
            by Haaheim
            Hi guys!
            I am currently working on a Parasound 2250 (class AB), which had one defective channel. Components in the signal paths have been replaced, including an output transistor (2SC3519).
            According to the manufacturer, bias is adjusted by measuring 1-3mV across the output resistors. The original ones are completely fine around 1.5mV, but the replacement is not. Initially, I got a couple from eBay, assumed they were fake (they were) and was able to source a replacement locally. This exhibits similar behaviour, being around 0.6-0.8mV on its emitter resistor....
            05-13-2022, 12:45 PM
          • reformatt
            by reformatt
            07-31-2025, 08:37 PM
          • CoinCoin88
            Garage door RX unit (Cardin S38C) does not short relay to send opening signal
            by CoinCoin88
            I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
            Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
            Yesterday, 03:36 AM
          • the_rem
            Unknown transformer : how to find a good replacement part ?
            by the_rem
            Hello guys,
            I would like a quite old but still good 800 W ATX PSU to be repaired. The problem was an extremely heavy coil whine coming from the small secondary transfomer on the PCB.
            I desoldered it hoping the references on the upper side would allow me to find a adequate replacement part. Sadly the written references drove me nowhere but to the manufacturer (I-MAG). I sent them a message like a bottle in the see asking them to send me a datasheet of the transformer. And... They responded ! I received a kind of datasheet (see attachment) but my competencies do not allow...
            04-23-2025, 01:48 AM
          • ezenia
            PS4 controller left stick potentiometer replacement issue
            by ezenia
            Not sure if this is the correct section, but I have a PS4 controller that I am trying to fix. It developed stick drift on the left stick and the usual simpler methods did not fix the problem.
            So I went on eBay and ordered some replacement potentiometers. https://www.ebay.co.uk/itm/174967976757 is where I got them from.
            I took the green potentiometers off the replacement sticks and soldered them onto the PCB. Assembled the controller and ran some tests. The drifting was somewhat fixed (not fully in center, but way better than before). However,...
            09-30-2023, 02:19 PM
