Parts suppliers? Need some smd caps
  • caphair
    • Nov 2011
    • 1249
    Looking for 10UF 35V X5R 0603 smd caps
    Both digikey and mouser don't have any in stock till early fall it seems.
    Any other parts supplier in the USA that would carry them?
    • 31277
    Re: Parts suppliers? Need some smd caps
    element14?
    • caphair
      • Nov 2011
      • 1249
      Originally posted by stj
      element14?
      Thanks but they didn't have them in a 35v rating
      • mariushm
        • May 2011
        • 3799
        How about stacking two of them, one on top of the other? ex buy 2 x 4.7-6.8uF 50v or something like that?
        • caphair
          • Nov 2011
          • 1249
          Idk if I'd have the space it's for an iPhone and it's part of a circuit that's under a shield
          • eryjus
            by eryjus
            05-10-2023, 11:21 AM
          • Paxman_Swede
            by Paxman_Swede
            Hello!
            01-14-2025, 09:51 AM
          • captain150
            by captain150
            03-16-2025, 07:34 PM
          • Foetuss
            Gigabyte GA-6OXT :: caps question
            by Foetuss
            Good evening
            I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
            Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
            But I was also suprised about the bigger boys, which are 330µF 25V.
            Could it be they used 25V caps because they were cheaper / available at that time?...
            02-11-2025, 12:22 PM
            by momaka
            03-12-2025, 03:42 PM
