how to measure hight tension ?
    I should measure a voltage >300 v at 40 KHz, I know that the cheap tester can measure voltage only around 50-60 Hz, I have an oscilloscope but not HT probe. there is a solution to have a good measure ?
    thanks
    Re: how to measure hight tension ?
    How about building Voltage divider circuit? Is the circuit in the hot side?
      I try with this circuit
      https://www.repairfaq.org/sam/hvprobe.htm
      but I don't know if a spike can damage the oscilloscope
        There are handheld DMMs available that are true RMS and 100KHz bandwidth.
        Fluke 287
        Keysight U1252 or U1253
        PeteS in CA
          My old Tek scopes are good for up to 400V P-P though I'm not sure why they have such a high limit, 8 divisions at 5V/division is nowhere near 400V.
          My Vu Data scope goes to 20V/division with 8 divisions, and thus one would hope that it can deal with 160V P-P.
          If you have a 10:1 scope probe, that's all that's needed for at least my scopes to deal with a 300V P-P signal...
