Pull-up resistor question / data lines
  • caphair
    • Nov 2011
    • 1249
    So in regards to pull-up resistors I understand how it works that there's a power rail that a resistor connects to to keep it at a known high state and when a circuit wants to get a low state it shorts it to ground to create a binary pulse
    My question is, how does the circuit/ic know when to pulse a line to ground? In other words how does a circuit know when to pulse a line down to 0v (low) to create data. Is it being triggered by another chip?
  • Longbow
    • Jun 2011
    • 623
    Re: Pull-up resistor question / data lines
    Threre are 2 reasons why you would use a pull-up (or down) on a logic chip or any other kind of chip. The first is that a particular input pin is not active in your design, but needs to be a solid High or Low. Without a pull-up or pull-down resistor in place, a logic input voltage can wander around aimlessly and cause lots of trouble.
    The second one is that the preceeding chip might be active in only one direction. In other words, whatever is driving an input (with a pullup) has an open collector output for example, and can only produce an active low. (low impedance path to ground)
    How does the circuit know when to create a pulse? That's up to the circuit designer. Logic chips do not create data. They respond to their inputs.
    Is it plugged in?
    • caphair
      • Nov 2011
      • 1249
      Your second reason is what confuses me. Could you elaborate more? Are you saying a chip before a pull-up will switch on pulling the rail voltage low and this low state is what is needed for that particular circuit?
        Active HI/LO:
        Open Collector output:
        http://www.evilmadscientist.com/2012...ector-outputs/
        http://www.electronics-tutorials.ws/...-resistor.html
        • Longbow
          • Jun 2011
          • 623
          Yes, you are right, but you still sound amazed. You can have untold fun with a breadboard, a 5 volt power source and a handful of TTL chips, LED's and so on. Logic circuits have some stated purpose, such as to turn on a light, or control a furnace. I recommend hooking up some TTL logic chips as an LED flasher. You will see how pull-up resistors are used.
          So, yes, the preceeding logic chip might (for example) be capable of 2 output states: open and active ground. When that chip is in an "open" or disconnected state, then the following chip has to provide its own input logic state (voltage) via the pull-up. When the preceeding chip changes to a LOW, or ground state, the following chip's input is forced to be LOW. Keep in mind that any particular logic gate is constantly receiving input information, processing it, and providing output to the next logical device.
          Not all logic inputs need pull-up or pull-down resistors. Typically you will need them with TTL devices, because their design provides an ACTIVE LOW output.
          Is it plugged in?
          • caphair
            • Nov 2011
            • 1249
            Ok thanks I guess my confusion stemmed from thinking of a chip has an active high due to a pull-up then there's no need for it to become an active low from a preceding chip pulling it to ground.
            In other words I was looking at it in a way that if a chip is using a voltage due to a pull-up then pulling it low turns that chip off and I couldn't see why it'd need to be pulled low
            • Longbow
              • Jun 2011
              • 623
              Looks like this is partially due to terminology. When a chip is said to have an ACTIVE low or high, it refers to the output, not the input. In this case the term means that the chip's output can source or sink current. The ideal device would have a very high input Z (won't load the source) and a very low output Z (can drive a load). When CMOS logic came along, you got pretty close to that ideal. Previous logic types like TTL, not so much.
              If a chip has a pull-up resistor on one of its pins, and no other connections, that would be called a "static" state. But in that case, no resistor would be required because the pin would never have to be pulled LOW.
              Is it plugged in?
              • caphair
                • Nov 2011
                • 1249
                Ah ok that helps.
                So for example, a preceding chip could ground a circuit thus completing the electrical path flowing in it and this produces an active high on it's output? Am I understanding that right?
                • caphair
                  • Nov 2011
                  • 1249
                  When there's multiple pull-ups on the same rail, does it create a low condition for all other circuits attached to that rail via other resistors when only one is pulled low or it has no affect?
                    "does it create a low condition for all other circuits attached to that rail via other resistors " Nope.
                    Lets say you have 10Vdc rail (that can handle lets say 1A) and you have Ten 1K resistors connected to that 10Vdc, and another ends of those resistors are not connected to anything else yet.
                    So if you connect one end of one of those Ten resistor to GND, will you see the 10Vdc drops down? How about all TEN resistors have other ends all connected to GND, will the 10Vdc drop down?
                    Notes: 10V and 1K load = 10mA.
                    • caphair
                      • Nov 2011
                      • 1249
                      So no unless one of those resistors was just a straight short to ground then the whole rail would be pulled down right?
                      So circuits need to be designed to handle the minimum current (in this example 10ma) in case all resistors were connected to ground?
                        Ten 1K resistors connected in parallel to the 10V power supply that can handle 1A (1000mA) and you will be drawing only 100mA so the power supply can easily maintain 10Vdc, if you use the power supply that can only handle 10mA then the power supply is not going to be able to handle 100mA load, it has to do with the output impedance of the power supply.
                        Study here:
                        https://cdn.badcaps-static.com/pdfs/...5fc335bf1a.pdf
                        http://powersupply.blogs.keysight.co...edance-of.html
                        • caphair
                          • Nov 2011
                          • 1249
                          Ok I ask because my curiosity of how digital power buttons work. How shorting a line momentarily enables something to turn on.
                          Also how data lines are constantly being grounded to create pulses
                            http://www.ni.com/white-paper/4453/en/
                            http://pcbheaven.com/wikipages/How_Key_Matrices_Works/
                            Switching can be done with active high, active low, Voltage level sensing, etc.
                            • caphair
                              • Nov 2011
                              • 1249
                              Thanks for those links.
                              Is there a way to know via a schematic if a resistor is blatantly being used as a pull-up/down?
                              For example the schematic attached, are r2260 and r2261 providing 1.8v to the reset and system alive lines, or is 1.8v being sent from those lines to the resistors? This confuses me at times
                                They are pull-up resistors.
                                You can also look up the spec sheet of that IC to see what the requirement are.
                                • caphair
                                  • Nov 2011
                                  • 1249
                                  No spec sheet it's an ic from an iPhone. Impossible to find spec sheets for their components.
                                  So if they're pull-ups that means those reset/system alive lines would always be pulled to 1.8v unless some other circuit pulls them low?
                                    Those pins are connected to other circuits which you should find so you can see how they function.
                                    The example above as you can see, the 'reset' has line on top of the word reset, which mean it will go into reset when that pin goes low, normal operation the pin will be high.
                                    Your IC 'RESET' pin is active high, so high = reset, so in normal operation that line should be low, but it has * after the RESET so you need to find out what the * is for.
                                    Another sample:
                                    https://cdn.badcaps-static.com/pdfs/...e24167a17b.pdf
                                    • caphair
                                      • Nov 2011
                                      • 1249
                                      Just took some measurements, there was 0v when the phone was off and 1.8v when it was on.
                                      So looks like it's in reset mode when that line goes low. That's why schematic is confusing it appears to be the opposite like you said
                                      • redwire
                                        • 3900
                                        01005 resistors are smaller than a pepper spec. You got guts measuring this!
                                        Notice your schematic net labels tell if a signal is an input or output or bi-directional.
                                        The body outline has an arrow: <- OUT, -> IN, <> BI for bidirectional lines. Bubble symbol means, example on RESET and IRQ, pulled low to assert.
                                        A MCU input can have a pullup or pulldown resistor or nothing- this is assigned in firmware.
                                        Pullup resistors are used on open-drain (driven) signals like RESET or IRQ because several IC's can activate (pull low) the line. It is a "wired-OR" setup. This IC or that IC can pull RESET low, for example.
                                        A MCU output can be push-pull or open-drain.
                                        For that iPhone, I think those are open-drain MCU signals (RESET and IRQ), so they need pullup resistors to +1V8.
                                        They should stay high unless pulled low by anybody connected to cause RESET. BUT during off/sleep I think the +1V8 is switched off so it is confusing.
                                          MSI Gaming Pulse GL66 12UGK-470CA Notebook GL Specification for Upgrade or Repair
                                          This specification for the MSI Gaming Pulse GL66 12UGK-470CA Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Pulse GL66 12UGK-470CA boardview and Pulse GL66 12UGK-470CA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-07-2024, 06:40 AM
                                          MSI Gaming PULSE GL66 12UGSZOK-1096 Notebook GL Specification for Upgrade or Repair
                                          This specification for the MSI Gaming PULSE GL66 12UGSZOK-1096 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the PULSE GL66 12UGSZOK-1096 boardview and PULSE GL66 12UGSZOK-1096 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-07-2024, 06:38 AM
                                          MSI Gaming PULSE GL76 12UEOK-692FR Notebook GL Specification for Upgrade or Repair
                                          This specification for the MSI Gaming PULSE GL76 12UEOK-692FR Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the PULSE GL76 12UEOK-692FR boardview and PULSE GL76 12UEOK-692FR schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          MSI Gaming Pulse GL76 12UEK-426XPT Notebook GL Specification for Upgrade or Repair
                                          This specification for the MSI Gaming Pulse GL76 12UEK-426XPT Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Pulse GL76 12UEK-426XPT boardview and Pulse GL76 12UEK-426XPT schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-07-2024, 06:21 AM
                                        • mikey5791
                                          Need help to replace burned resistor in 350w atx psu
                                          by mikey5791
                                          Hi to all forum members,
                                          Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
                                          The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
                                          Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
                                          Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor...
                                          12-26-2024, 04:55 AM
