capacitors
  • Humphrey1
    • Nov 2008
    capacitors
    I am recapping an sx280 dell mb with a kit listed by badcaps. The list shows 3 1500uf 6.3v 10MM caps but my mb has 3 1500uf 16v 10MM caps. My question is "which ones should I use"? Thanks Humphrey1
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: capacitors
    16v caps are on 12v power rail.
    Can't use 6.3v caps on 12v rail.
    It's possible a previous recapper used 16v caps on a 5v or 3.3v rail because that's what he had on hand. That doesn't make for an electrical problem [16v is fine on lower voltages too] but the only way to know that's what happened is to see a board with original caps [to see what voltage they are] or to check the voltages on those 16v caps with a meter.
    If you can post a pic of the board (if no camera then steal a pic from the web) and identify the caps positions then someone familiar with that board (or that has one) can tell you what is installed there.
    Mann-Made Global Warming.
    - Dr Seuss
    • eryjus
      by eryjus
      05-10-2023, 11:21 AM
    • ssl6
      MSI K7T266 Pro (Ver. 1.0)
      by ssl6
      Hey Everyone,
      Long time lurker, but I think this is my first time posting.
      Just looking for some assistance on identifying some suitable replacement capacitors for an MSI K7T266 Pro (Ver. 1.0). I just got my hands on two of them actually, both working but one has some visibly bulging capacitors and the other has a few that I can't tell for sure if they're bulging because it's faint at best if they are.
      I'll be honest I don't fully understand much on capacitor spec sheets beyond voltage and capacitance but I can solder like nobodies business so I've...
      11-09-2023, 01:00 PM
    • SwedishDiesel
      Dell Optiplex GX260 - Advice Needed for Polymodding Motherboard
      by SwedishDiesel
      Howdy folks,
      I have an Optiplex GX260 that blew a couple of those troublesome Nichicon HM series (ultra low ESR) electrolytic capacitors. Because said caps are obsolete, they are pretty much impossible to find on the market; I did find a listing for some but I believe they are counterfeit. I feel the easiest thing to do would be to replace all the blown caps with polymer ones. I am by no means an expert in electronics, and I've found a fair bit of conflicting information, so any guidance or confirmation would be greatly appreciated. While from a practical standpoint it's not worth...
      10-30-2021, 12:47 AM
    • Paxman_Swede
      by Paxman_Swede
      Hello!
      01-14-2025, 09:51 AM
    • captain150
      by captain150
      03-16-2025, 07:34 PM
