restoring a 1949 tv set
  • capwizard
    • Jun 2016
    • 1991
    restoring a 1949 tv set.........Where I can buy clothes like him?
    https://www.youtube.com/watch?v=ppj3gqUTt9E&t=1s
    PS: Look at 1:29:53 extendable flat tv antenna !
  • dclass-pro
    HP 440 G2 no power after short in flat lcd
    by dclass-pro
    Hi all guys, I need your help. On a HP 440 G2 - LA-B181P laptop I was changing the speakers and the pc worked fine everything ok.
    After closing it all with all the screws I realized that it would no longer turn on. I opened it and found that the flat cable of the LCD was shorted. I ordered a new flat but the motherboard still won't turn on, as soon as I connect the power supply the connector LED always flashes and the power button stays on.
    I tried to check the voltages and the 3v and 5v are there, on the battery pin (with no battery connected) I have about 2v.
    I tried to...
    08-11-2023, 07:47 AM
  • reformatt
    A2337 not working with flat battery
    by reformatt
    Looking for some advice on a 820-02016 board as I don't have much experience with these M1 machines. Learning the nuances of them as I go.
    So the history of this machine was it had been in a bag where a bottle of water leaked. Presented as dead about a month ago, corrosion was mainly around the battery connector and it's sub-PCB. Some corrosion was noted on the board around UC300, CC325, CW1C7, CW1C8. That was it really.
    Now without battery connected, USB-C will stay at 5V and cycle between 0 and 120ma. PPBUS_AON is cycling between 0 to 12.3V. If battery is connected,...
    10-12-2023, 04:36 PM
  • speggio91
    Macbook Pro A2251 820-1949 5V cycling
    by speggio91
    Hello everyone, I've searched the forum but couldn't find a case with the exact same symptoms, so I'd appreciate some advice.
    I'm working on a macbook pro late 2020 with the board 820-1949. The laptop came in with visible liquid damage and corrosion in various areas:
    -speaker amp right side (C6483, C6455) - no shorts detected
    -keyboard backlight area (pin 2 of J8401 was destroyed plus some minor corrosion)
    -C2070 corroded under the pads
    -The most afflicted area is around UB260, RB296, RB29A, RB291, RB263, U3100_R (just a bit on the right side), all the area...
    03-31-2025, 05:14 PM
  • Joe24
    Maytag Whirlpool Kenmore clothes dryer data bus
    by Joe24
    Patient is a Maytag/Whirlpool/Kenmore clothes dryer. Not sure of exact model, doesn't matter. All boards are out of production.
    Specific problem is a Maytag 8544799 / WP8544799 motor-control board, aka Diehl Controls 708879-05. Customer states the board "doesn't work, motor doesn't run". Not sure how the repairman made that assessment, or if it's even accurate. He can't get replacement boards, and the owner decided to buy a new dryer, so whether this board is the problem is speculation on his part. Again, doesn't matter.
    I've been over the board looking for...
    01-13-2025, 06:50 PM
  • rookiecap
    fixing flat two tv screens
    by rookiecap
    I am trying to fix two flat tv screens. They have problems that I am not familiar how to deal with and if they are fixable at all.
    1) the first TV is RCA 32: LCD combo tv+dvd, model RLCDV3282A-B. It was distorting images in sync with sounds. The sounds were distorted too. Then it was shutting down automatically. I replaced all visible electrolytic capacitors on power supply board. After repair, the image and sound are restored but tv still shuts downs unexpectedly usually after couple of minutes. I do not know what to do next. What might be the culprit and how to trace/inspect...
    07-31-2024, 05:48 AM
