Can diode be replaced with a lower voltage rating?
  • caphair
    • Nov 2011
    • 1249
    If a diode rated for reverse voltage of 30v fails and all you have is a 20v would it safely work?
  • petehall347
    • Jan 2015
    • 4440
    Re: Can diode be replaced with a lower voltage rating?
    depends on the circuit
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8703
      indeed, depends on if the circuit was overrating it, but chances are that it wasn't, and the PRV was selected for a reason.
      • caphair
        • Nov 2011
        • 1249
        It's for a backlight circuit in an iPhone 6. Schematics say the 6 plus uses 20v while regular 6 uses 30v
        Want to use one from a donor 6+ board in a 6
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8703
          Probably can get away with a lower voltage then, but don't be surprised if it dies again...
          • mariushm
            • May 2011
            • 3799
            IMHO you should stick with 30v, unless you really investigate the circuit thoroughly.
            The 6+ may use better binned leds (with lower forward voltage), or the 6+ may have fewer leds in series, allowing for lower voltage, or the 6+ could use a better backlight driver which may not "overshoot" as much (maybe runs at higher frequency, maybe has faster/better feedback etc)
            • quickname
              Cyberpower 1500AVR UPS repair
              by quickname
              I'd like to start out by thanking this forum for providing the info to be able to repair my 15 year old CP1500AVRLCD UPS. Here is all the info I gathered during my trouble-shooting and re-capping.
              I decided to verify that the batteries were...
              11-12-2023, 09:57 AM
            • hikomalek
              SYMSI70 gas heater, TOP247Y exploded, power supply, snubber network
              by hikomalek
              Hello, I have a SYMSI70 gas heater board, which has issues with its primary side power supply, controlled by TOP247Y chip.
              When I replace a TOP247Y it explode in 1 second. I have desoldered transformer and measured a winding ratio, so transformer looks like OK.
              Transformer:
              |Info| Primary | Aux | AB | CD|
              |Ratio|1|25|40|12|
              |Voltage AC|230V|9.2V|5.8V|19V|
              |Voltage DC (*1.41)|230V|13V|8.1V|27V|
              I have disabled a undervoltage protection of TOP247Y, disconnected secondaries and tried to power it up...
              09-19-2025, 03:30 AM
            • Tynan Dill
              by Tynan Dill
              Assuming...
              11-22-2024, 01:46 PM
            • abajor
              A2141 PP3v3_G3H_RTC_X Diode Reading .104V Voltage 3.39V
              by abajor
              Have an A2141 which is reading about 5.2V 0.07A on all USB jacks, started doing the measurements.
              PPBUS_3GH diode: measures good .45V
              PPBUS_3GH Voltage: maybe not so good 12.25V maybe bad T2? Unit did not come up in DFU on configurator.
              The weird so far is
              PP3v3_G3H_RTC_X diode: .104V (WTF?)
              PP3v3_G3H_RTC_X voltage: 3.39V (Normal)
              Stopped there attempted reverse voltage injection at PP3v3_G3H_RTC_X with 1V. Instead of the circuit sinking any current, My PSU suddenly reads 3.4V with no current draw.
              Not sure what any of this means...
              03-18-2025, 10:27 PM
            • mon2
              A1466 Macbook Air (Liquid damage repair)
              by mon2
              Hi. Recently serviced a damaged A1466 Macbook Air. Thought to post the issues and resolution for each.
              Macbook AIR Model A1466 Diagnostic 09-01-2021
              Issue: Liquid damaged (beer spill) Macbook AIR will not power up.
              Problems & Resolutions
              1) Attached Apple magsafe power adapter. No green / no orange light. This confirms the absence of the PP3V42_G3H voltage rail. The PP3V42_G3H rail is the primary voltage rail necessary to communicate with the magsafe power adapter to report the green or orange light status to the end user....
              09-01-2021, 09:31 AM
