Where to get miniature caps?!
  • Scenic
    o.O
    • Sep 2007
    • 2642
    hi
    well.. i had to temporary fix my LCD monitor (HP L1820) a few months ago..
    those Elite and Lelon caps in there were all bad.
    because i needed the LCD i temporary fixed it with some (partly) junk caps that were way too big connected with wires to the original cap locations.
    i searched for matching and fitting miniature caps, but couldn't find any.
    they were either too big to fit inside there (so i wouldn't be able to put the LCD back together) or they would fit inside there, but they didn't have matching values.
    as the temporary fix worked quite good (allthough i mixed up all caps that i could find... rubys, pannys, OSTs, and g-luxons.. partly even in series) i "forgot" about searching for a real fix..
    now this temporary fix seems to die on me again
    the backlight randomly turns off when the LCD warms up a bit..
    so i added a pc-fan on top of the LCD (where the openings are) running at 5V. seems to be enough to keep it working for a few hours..
    but .,.. well.. that temporary fan-fix for the temporary cap-fix pretty much sucks..
    so now i really need to find matching and fitting replacemend caps.
    i went through my fav. ebay cap sellers ( PCMCS and audjade_chn ) and through big pope's cap database .. unfortunately without luck
    i took a pic of the desoldered caps.
    Lelon is 16V 220uF
    Elite is 10V 220uF (but i cant use 6.3V caps for those, because the voltages where those Elite craps were range from about 3V to 9V.. so 6.3V isn't really an option..)
    click for full size
    the ruby is just for size comparison (to show how small the other ones really are)
    most of those caps lost at least 1 leg while desoldering (-.-)
    the legs came out of the cap itself, but not out of the pcb
    Elite:
    height: 5mm (without legs)
    Lelon:
    height: 7mm (without legs)
    diameter: 7.5mm (8mm?!) -> same for elite and lelon
    pin pitch: 3mm -> same for elite and lelon
    any ideas..?! :/
  • Gianni
    • Jul 2008
    • 681
    • Italy
    Re: Where to get miniature caps?!
    I bet this caps are custom size.
    I have searched but I have found nothing in the same shape but something that maybe can do the job:
    Panasonic
    http://it.rs-online.com/web/search/s...duct&R=1883159
    150μF 6,3V 105°C pin pitch 3.5mm height 10.5mm dia. 8mm
    If you can use SMT type you can try this one:
    Panasonic FK
    220μF 16V 105°C height 6,2mm dia. 8mm
    http://it.rs-online.com/web/search/s...duct&R=5370455
    Panasonic FC
    http://it.rs-online.com/web/search/s...duct&R=5370067
    You can search also on Digikey
    I hope you can use RS in your country.
    If you have already checked here (RS, Digikey) forget my post.
    Ciao
    Gianni
    "In the confrontation between the stream and the rock, the stream always wins...Not through strength, but through persistence."
    H. J. Brown
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      You will have less troubles sourcing replacements if you can fit 11-12mm tall caps in there.
      Specs for old ones:
      Lelon SG series 220uF 16v
      8mm diameter, 7mm length, 3.5mm Lead Spacing, Ripple 146 uA, not low ESR
      I can't see the series on the Elites.
      Mann-Made Global Warming.
      - Dr Seuss
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        You could use 16v caps to replace both the Lelon and Elites.
        - Dr Seuss
        • Scenic
          o.O
          • Sep 2007
          • 2642
          thats what i wanted to do..
          there's the problem: i can't
          if i put 11mm tall caps in there, i can't get the LCDs back cover back on
          soldering them in in parallel to the board (meaning: lying flat on the board) isn't possible everywhere on the PCB too.. surrounding components in the way.. :/
          Specs for old ones:
          those elite seem to be "SB" series... even less tall than those lelons..
          damn,... this LCD is a really nice piece of hardware... as long as it works at least :/
          DVI and VGA, 18" 1280x1024, lots of CCFL tubes (brightness is incredible... i just cant remember if there were 6 or 8 (!) CCFL tubes in there) and it was used for only ~70 hours before i got it (at least the backlight info in the OSD menu told me this..)
          and i got it for 20€ (= 27,52 US$ ATM) beacause the power brick was missing (12V 4A .. running off my PC PSU now.. so i don't even need to turn the LCD on or off anymore )
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            Elite SB series 220uF 10v is also not low ESR.
            8mm diameter, 5mm length, Ripple = 120 uA
            GP caps would be fine.
            - Dr Seuss
            • Big Pope
              Approved Vendor
              • Dec 2005
              • 426
              Originally posted by Scenic
              hi
              Lelon is 16V 220uF
              click for full size
              Elite:
              Lelon:
              any ideas..?! :/
              If you dont' hurry, i can order some height 7mm caps (Samxon ZS or KS) for you from factory directly. It is not a problem.
              Just let me know if you want.
              My SAMXON Capacitors Database HERE!!
              X-CON is a new brand for SAMXON's Polymer Capacitors.
                HP Elite Elite 7200 MT Elite 7200 i5-2400 Specification for Upgrade or Repair
                This specification for the HP Elite Elite 7200 MT can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Elite 7200 MT boardview and Elite Elite 7200 MT schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                09-12-2024, 03:44 PM
                HP Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) Compaq Elite 8000 E5500 Specification for Upgrade or Repair
                This specification for the HP Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) boardview and Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request...
                HP Elite Elite Slice (ENERGY STAR) Elite i5-6500T Specification for Upgrade or Repair
                This specification for the HP Elite Elite Slice (ENERGY STAR) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Elite Slice (ENERGY STAR) boardview and Elite Elite Slice (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                HP Elite Elite Slice Elite i5-6500T Specification for Upgrade or Repair
                This specification for the HP Elite Elite Slice can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Elite Slice boardview and Elite Elite Slice schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                HP Elite Elite 7100 Microtower PC Elite 7100 i3-530 Specification for Upgrade or Repair
                This specification for the HP Elite Elite 7100 Microtower PC can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Elite 7100 Microtower PC boardview and Elite Elite 7100 Microtower PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
