Choosing a new multimeter
  • ocf
    • Jun 2016
    • 157
    I've been using my meter a lot more and the current one isn't cutting it. Currently using a very budget chinese multimeter, probes are falling apart and the dial is clunky as hell.
    I don't have the dough for a fluke, I found the following meter - https://www.amazon.co.uk/gp/product/...A3DWL9I0SG4MBZ It looks more solid than my current one, autoranging also states it can test capacitance in the following ranges
    Capacitance:
    40nF/400nF/4uF/40uF/400uF/2000uF
    I know I need an ESR meter to test caps in circuit, can anyone tell me if the capacitor test feature on the multimeter I linked above is comparable to the functions an ESR meter offers, if not how does it differ?
    -OCF
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Choosing a new multimeter
    For another 5 pounds, you can get a Fluke 101 off ebay. The Fluke 101 won't measure current, but for 97% of troubleshooting all you basically need is volts and resistance.
    Of course, you may be working on projects/repairs that would require current measurement.
    The Fluke 101 will survive any "oops" moment. Forgot to turn off power while measuring the 450V high voltage filter capacitor with 101 set to ohms mode? No problem.
    Capacitance:
    Measuring capacitance and ESR are two totally different things. No handheld multimeter can measure ESR.
    Be aware that measuring anything in circuit is not 100% reliable. Other components in the circuit could be affecting the reading. To get a 100% correct reading, you have to desolder the component.
    --- begin sig file ---
    --- end sig file ---
    • retiredcaps
      • Apr 2010
      • 9271
      The Vici VC99 that you linked was in Dave's $50 shootout from 6 years ago.
      https://www.youtube.com/watch?v=ZoeUgMFLyAw
      Dave throws 5000V at it as well
      https://www.youtube.com/watch?v=sKcH4JxnxbQ
      • Per Hansson
        • Jul 2005
        • 5895
        • Sweden
        Well there are some niche meters that can do LCR, but they are quite expensive.
        The Agilent U1733C is one that can test up to 100KHz which is nice.
        But I know of no combined handheld multimeter with LCR function.
        Generally you don't need that kind of precision though.
        I find the old Bob Parkers MKII ESR meter works just fine for my needs.
        Or the more recent "transistor tester" which you can find info about on eevblog or here.
        http://www.eevblog.com/forum/testgea...ecker-project/
        When it comes to multimeters it helps to know your usage; I would never recommend a cheap meter for measuring high capacity power networks.
        But if you never do line voltage tests then sure a cheap meter can be ok.
          • 31138
          what do you want to meter with it, and what's your max price?
          btw, i have never been concerned about using a cheap meter on domestic mains.
          they have a number of safety features.
          one such feature is cheap leads that will fail to protect the meter
          another safety feature is the fact that most humans have 2 hands - so the meter will not be in your hand while your holding the probes.
          • ocf
            • Jun 2016
            • 157
            thanks for the input guys, I think I will go with the fluke 101 as current measuring is not important and I can rely on my cheapo meter for that.
            • retiredcaps
              • Apr 2010
              • 9271
              You can make your own shunt if you want to measure current.
              Let us know how you feel about the Fluke 101 after you have used it for a week or two.
              PS. Just be aware that the Fluke 101 is intended for the China and India markets and there is NO WARRANTY from Fluke it it is sold outside those countries.
              The Fluke 101 warranty is only 1 year. The more expensive Fluke meters have a minimum 10 year warranty.
              Nonetheless, the 101 is a very popular meter over at eevblog and there are numerous reviews, teardown photos, etc.
              • ocf
                • Jun 2016
                • 157
                I got the fluke 101.
                It's smaller than I expected but feels solid, good leads also.
                I'm trying to test some IGBT's but not getting the results I'm expecting. When I put power on the gate of the IGBT from a bench DC power supply I get connection source to drain. When I use the Fluke 101 +V lead on the gate and then check the source to drain I get nothing.
                Manual/Spec sheet for the fluke doesn't mention what voltage it outputs in diode measurement mode. If I remember correctly the IGBT's I'm testing have a 4v gate threshold voltage. I might look that up again to confirm.
                Any suggestions on what I could be doing wrong?
                • ocf
                  • Jun 2016
                  • 157
                  • retiredcaps
                    • Apr 2010
                    • 9271
                    You are not doing anything wrong. The Fluke 101, as you found, sources 2V in diode test mode. With 2 AAA, that is reasonable.
                    I know that my Fluke 87V sources around 7.9V, 1mA in diode test/600 ohm using a 9V battery.
                    There are pros and cons with too much or too little voltage. Too much and you risk damaging some sensitive components. Too little and you can't light an LED or turn on an IGBT.
                    I'm no expert on IGBTs, but a quick look at some sample datasheets suggests the turn on voltage is anywhere from 5V to 6.5V. Very few handheld multimeters can source that. Even meters that use a 9V battery, they are typically in the 2.5 to 3.5V range.
                    From reading some of the common plasma TV problems, IGBTs usually fail shorted. So a simple ohms resistance check is all that required to determine if the IGBT is bad.
                    Some of the "how to test a IGBT" search results suggest using a 9V battery if you want to test the turn on/off.
                    • ocf
                      • Jun 2016
                      • 157
                      Thanks for the info, really helpfull. I guess I will test using resistance and use an external power source if I want to test them on/off.
                        12-31-2023, 06:04 AM
                      • Baldbentley
                        repairing a Fluke 335 clamp meter
                        by Baldbentley
                        I am repairing a Fluke 335 clamp meter. After contacting fluke it appears there is no service manual or circuit board/ component list available. I have determined that there us a faulty PNP bipolar junction transistors shown in the pictures. I am having trouble sourcing this transistor. I pulled a good one off of the board and tested it with my component analyzer but I cannot find anything that matches the specifications. Any help locating this part or a replacement would be greatly appreciated.
                        Thanks...
                        10-18-2023, 02:05 AM
                      • rcanpolat
                        M1 MacBook Pro 2021 A2485 - No backlight display
                        by rcanpolat
                        I recently got my hands on an M1 MacBook Pro (2021, A2485) that I suspect suffered some liquid damage. I have a hot air station and the basic tools to work on the board, but I’m new to SMD repair and would love some guidance before diving in.
                        Here’s what I’ve observed so far:
                        • When I power it on, I hear the MacBook chime and, with a flashlight, I can see the Apple logo on the screen. However, it never completes the boot and eventually powers off. My plan is to try to get the display fully working first, then tackle the boot issue.
                        • I did some basic resistor
                        08-24-2025, 02:16 PM
                      • smali
                        Fluke 189 multimeter rotary switch contacts
                        by smali
                        Hi
                        My Fluke 189DMM rotary contacts are missing. Can anyone tell me where to find them or any other way to make it?...
                        01-03-2022, 06:56 AM
                      • Pauldg1
                        Fluke 289 multimeter not working
                        by Pauldg1
                        I have a Fluke 289 multimeter which does not work.
                        Have anyone an idea what could be the cause?
                        When I turn on the device only the green led is continuously on, and strange stripes are present in lcd screen. I can only turn off the device by removing the batteries.
                        Any suggestions will be appreciated...
                        04-05-2021, 07:47 AM
