WaveTek Synthesized Function Generator Model 288 20Hz to 20Mhz
  • rlb245
    Smillie
    • May 2016
    • 14
    Re: WaveTek Synthesized Function Generator Model 288 20Hz to 20Mhz
    Well haven't been able to update this post for a while. Was out riding one morning and the horse desided the bush beside the trail was a monster and gave me a toss on to some rocks. got busted up pritty good. but all most backup to running speed again. at least I can use my right hand again.
    Anyway LongBow you can say I told you so. changed out bad caps and it didn't cure the proble. I haven't been ate the bench much, To hard to sit for any period of time. hopefully I can get back to it soon. This layimng around is killing me, dam boarging it is
    Sorry for the ill timed event but horses are like that, but i love to ride, and i can't think of a better way to spend a beatiful morning.
    PS:Longbow! I think Im going to go right to the out put board.
    Life is full of little inconveniences
    • Longbow
      • Jun 2011
      • 623
      Let me just say a word about troubleshooting. Unless you have already fixed 500 model 288's, or anything else for that matter, you must have a METHOD. In other words, don't start replacing capacitors until you verify that the unit is plugged in. Great! you have checked the main power supplies. Note that there are other secondary supplies close to various circuits throughout, so you are not done with the supplies. With such a great manual to work with, it shouldn't be a problem. I would say offhand go to the page marked "Schematic Phase Lock Loop" Sheet 4 of 5. Do you have a triangle wave at F01 C7 which is labeled "triangle out"? If so, move forward. If not, move back. Simple. Instructive.
      Is it plugged in?
      • GDTest
        • Aug 2019
        Originally posted by rlb245
        Ill give you a shout if this cures it
        Were you able to get the Wavetek 288 up and running? Do you go through the calibration steps. I have a the same unit and have not been able to make the adjustments to correctly set the amplitude output. I have been using the manual available pretty much everywhere, and also a military version of the manual from radionerds that is much clearer but may have incorrect adjustment procedures.
        • Dannyx
          Wind generator charger schematics (or load of baloney ?)
          by Dannyx
          Good day folks. A former colleague of mine recommended me to a relative of his and I got to speak to this man today in person. He's a bit of a mad scientist/tinkerer sort-of guy - just my kind of weirdo Apparently this chap builds all sorts of generators and wind turbines in his little shop at home and sells them here and there. He even showed me some footage of some of his inventions in action out in the field. However, as he himself very kindly put it, he's not good with electronics - he just designs and builds the generators (from scratch, I might add) and turns to others for the electronic...
          09-16-2022, 11:13 AM
        • PM5K
          Inverter Generator Repair
          by PM5K
          I have an inverter generator that has two bad caps. One blew and the other was swollen.
          My main issue is that the power supply
          is encased in some type of epoxy.
          My main concerns are regarding the epoxy and its purpose. I can imagine that it helps with vibration should I also be concerned with sparks since it's a gasoline generator?
          The plan is to break off the old caps, cut the old legs off, clear out the solder points, then solder from the top since I cant get to the backside of the board.
          This means that the legs of the caps...
          01-13-2023, 03:15 PM
        • jason123
          Agilent 33220A 20 MHz Function Generator
          by jason123
          I can't find a forum to discuss "instrumentation Troubleshooting", but PS maybe the closest.
          So, I'm having an issue with about 13 year old Agilent Function Generator. it works, passes self-test, but it has an annoying "audible" noise, that changes as I change the output frequency setting of the instrument. Prominent around 600 Hz and up (at least that's what my ears are picking up.) I saw on some forms that it could be fan, linear regulator, dried up caps,... I can't seem to find the source of audible noise. Here is what I tried:
          1. Turn the output off - still...
          07-01-2025, 08:12 AM
        • Nevillet
          Square wave (from a function generator) Vs a pulse generator
          by Nevillet
          Hi All,
          Can someone please explain the difference between a 1kH square waveform with a 50% duty cycle and a similar waveform from a pulse generator?
          Many thanks,
          10-09-2022, 02:39 AM
        • technodruid
          Wavetek 130 Output issues
          by technodruid
          First post!
          Last night I finally got a chance to try out a wavetek 130 that I purchased a year ago or so after finally getting unpacked from a move. It was working really well, I was testing the various settings from the 50 ohm output into my rigol scope and it seemed to be fairly accurate. I was stepping through the course adjust from x10 to x100 and sweeping the dial looking for any distortions or drops/rises in amplitude. It all looked great.
          Then when i switched to the 1M setting, the sine wave disappeared. I moved back to x100k and the sine wave was still gone. Something...
          04-04-2024, 10:32 AM
