Help with a Capacitor
  • odotb3
    • Dec 2015
    • uk
    I recently acquired an old Grundig TV from 1982. Series 815 CUC 95. Somebody I work with was just going to throw it away! I'm a retro gamer so I know these old CRTs give the best picture with old school gaming consoles. And I was right, playing Super Mario bros 3 on an NES on this TV compared to a modern day LCD is like night and day!
    So anyway, I was playing smb3, got to world 7 and decided I would take a break. I left the TV on and came back an hour later to a room full of smoke! The TV was still running fine and after the initial shock of the thought that my house was burning down, I opened the back case of the TV to find a metal film cap had exploded! I slid the board out of the chassis.
    [/URL][/IMG]
    Now, it is my understanding that this TV was not in use for some years, and after some heavy use from me over a period of a few days, the cap decided to give up. Assuming they've never been replaced, these caps are nearly 35 years old.
    I'm wondering whether the cap blew from age, or something else caused it to blow? I cannot find a (free) copy of the service manual. Having said that everything else looks ok.
    I'm just going to replace it. The cap says 0.15 250v~ wima mp3. The markings on the back say N3 560-7 X. However I cannot find a suitable replacement locally. This is the only one I can go around the corner and grab but its voltage is rated much higher. I know you should never decrease the Voltage rating, however I am unsure whether this is a suitable replacement. I was also wondering whether the type of film capacitor is important.
    There is another cap on the same board which is identical and im thinking of replacing that one as well.
    [/URL][/IMG]
    [/URL][/IMG]
    Thanks in advance to anyone who can help!
  • MORETTIGIAN
    by MORETTIGIAN
    Title:
    Description:
    Procedure performed:
    - Removed backplate
    - Reapplied thermal compound
    - Reassembled card
    09-18-2025, 12:14 PM
  • Prolog
    by Prolog
    12-01-2024, 08:27 PM
  • Agent24
    Dick Smith Q-1760 linear power supply filter capacitor question
    by Agent24
    I have acquired a used Dick Smith Q-1760 power supply - although the OEM is Manson Industrial
    It has at least one problem.
    The voltage control potentiometer VR2, 50K is faulty - going high resistance / open circuit in the CCW end and leading to the output voltage jumping around.
    I have already ordered a replacement potentiometer, so that's not an issue.
    Now, I want to replace all three electrolytics on the PCB as they are CapXon and I don't trust them so much, I will replace them with something better while I've got the thing apart anyway.
    All are CapXon...
    10-21-2025, 05:39 PM
  • chth96
    by chth96
    12-22-2023, 04:34 AM
  • chth96
    by chth96
    06-02-2024, 07:31 PM
