Troubleshooting electric bike battery pack, Lithium Ion 36V 9Ah
  • Chungalin
    • Jul 2014
    • 423
    • Spain
    This equipment doesn't match a more specific subforum, so I'm posting here.
    I have a 36V 9Ah battery pack for an electric bike that is not charging well and has a lower voltage than nominal.
    I've disassembled it and it consists of a matrix of 20x CGR18650CG Lithium Ion cells. It's arranged in a 10x4 grid, meaning: 10 packs in series of 4 cells in parallel (10 x 3.6V = 36V; 4 x 2250mAh = 9Ah).
    I've measured each pack of 4 cells and the first ones (from first (+) to sixth) they all read about 4V (correct), while from seventh to tenth (-) they read between 1.5 and 1.9V. I've split the individual cells of this 4 suspicious groups, hoping to find one of them specially dead... but not. All cells in a group read the same low voltage, not higher, not lower than the whole parallel group.
    The charger has a test point to each union between the 10 packs.
    What can be wrong? I've seen several vids on YT that show how to revive LiIon cells, but that trick doesn't seem to apply to these.
    • 31246
    Re: Troubleshooting electric bike battery pack, Lithium Ion 36V 9Ah
    read the voltage of all the suspect cells - write it down, then wait a few days and repeat the test.
    one of the cells may have a bad internal resistance.
    • Chungalin
      • Jul 2014
      • 423
      • Spain
      Interesting point: the time factor. Thanks!
      Then you mean that good cells with rise its voltage slowly by themselves while the bad one will keep low?
        • 31246
        i was thinking more that a poor cell would slowly deplete itself through internal resistance.
        • fzabkar
          • Mar 2009
          • 772
          FYI, you can safely measure a low voltage battery's ESR with Bob Parker's ESR meter.
          • Chungalin
            • Jul 2014
            • 423
            • Spain
            I have EVB ESR meter but I’ve never used it for measuring batteries. I’ve read official website ( http://clientes.netvisao.pt/greenpal/information.htm ) and looks like it’s not safe for the meter to measure batteries ESR with normal probes. I don’t know if this warning applies to all kinds of batteries or just larger ones. I’ll ask to the maker/vendor.
              • Jul 2011
              • 6069
              Originally posted by Chungalin
              I’ve measured each pack of 4 cells ---? while from seventh to tenth (-) they read between 1.5 and 1.9V. I’ve split the individual cells of this 4 suspicious groups, hoping to find one of them specially dead... but not. All cells in a group read the same low voltage, not higher, not lower than the whole parallel group.
              You need to split the individual cells and very slowly charge them at no more than at 100 milliamps BUT only do this for cells that have a reading of 1.9 volts or more
              The ones that read 1.5 only charge them with no more than 50 milliamps
              Also watch the voltage when you first put them to charge if after an hour the voltage dose not go up ANY then they might not be good any more
              One very important thing is keep a very close on the temperature of each cell if they start to get warm STOP charging them they are to far gone to revive them
              I have done many time before some time they come back and some time they do not but they will not have full power any more
              Please be careful when doing this
              • brispuss
                Ryobi 36V (aka 40V) 6Ah Faulty Battery Pack
                by brispuss
                Purchased a Ryobi 36V 6Ah battery pack maybe just over a year ago.
                Battery pack had been used on about 3 or 4 occasions for powering a cordless lawnmower. I was wanting to use this battery pack again recently, but on checking the battery charge state via the battery pack test button, there was no LED indication at all of charge state which suggested the pack was fully discharged.
                I found this to be odd as I usually fully recharge battery packs shortly after use. So either the pack developed some sort of fault which completely discharged the pack cells (after recharging),...
                12-28-2022, 02:58 AM
              • reessi
                Help with Charging Lithium Battery Pack from an E-Bike
                by reessi
                Sorry if it is in the wrong section but there is not a correct section and since many portable devices are charging lithium packs I put it in here.
                Please see the photos. The model is -> NKY341B2 (26v @ 8AH).
                Googling does not give much information. But I have established it is a nominal 26v pack when flat and 29.4v fully charged.
                I can buy a universal charger off ebay at exactly 29.4v, charging at 2A. It is the perfect voltage and current limits but has only plus and minus no data signals.
                On the photo you will see from left to right...
                02-16-2020, 02:08 AM
                MSI Infinite A VR7RC-003DE + Gaming Pack Infinite i5-7400 Specification for Upgrade or Repair
                This specification for the MSI Infinite A VR7RC-003DE + Gaming Pack can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Infinite A VR7RC-003DE + Gaming Pack boardview and Infinite A VR7RC-003DE + Gaming Pack schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                09-12-2024, 03:28 PM
                ACER Aspire AspireRevo R3600 + Gaming Pack Aspire 230 Specification for Upgrade or Repair
                This specification for the ACER Aspire AspireRevo R3600 + Gaming Pack can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire AspireRevo R3600 + Gaming Pack boardview and Aspire AspireRevo R3600 + Gaming Pack schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                Acer Aspire A317-52-39NP+Pack Gold17 Notebook 3 Specification for Upgrade or Repair
                This specification for the Acer Aspire A317-52-39NP+Pack Gold17 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A317-52-39NP+Pack Gold17 boardview and A317-52-39NP+Pack Gold17 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                09-06-2024, 09:10 PM
