Each video input with DDC has different EDID data
  • japlytic
    • Oct 2005
    • 2086
    For video inputs with a DDC data bus, I found that the EDID data is typically different for each input on the same display device, even when compared against two or more HDMI inputs.
    One reason why is that different inputs might support different capabilities (even on HDMI inputs), and for digital inputs, a good chance that the HDCP key is different for each input.
  • ugamazing
    820-02020 Super Weird Issue: Keyboard Input Character Map "Wrong"?
    by ugamazing
    So, I have a really bizarre issue that I'm struggling to identify the cause of. Working on an 820-02020 board with some bizarre keyboard/input-source character mapping. My suspicion is a possible damaged SPI ROM (U1970), perhaps, but I'm really not sure in this case:
    1. The issue is pretty weird, but when installing MacOS, I noticed my WiFi password did not work. I quickly realized the special characters (!@#$%^& etc) were not mapping correctly.
    2. I noticed the keyboard layout/input-source is defaulting to JAPANESE every single time I restore the board. I am not...
    04-10-2024, 08:06 AM
  • FrancescoV
    Onkyo HT-R390 no sound output, video output ok
    by FrancescoV
    Good morning everyone,
    I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
    The firmware reported is the following:
    M:1.00/11107BLP
    D:?.??/????????
    O:1.00/11107AL
    The DSP firmware given the question marks seems corrupt.
    On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
    05-11-2025, 02:59 AM
  • redbaron1007
    Crua CR270C shorted input.
    by redbaron1007
    I've got a Crua CR270C that had a short to ground on the input jack. The input was rated at 12v 4A center pin positive. When I took the board out and powered it with my bench power supply it jumped to 3v and 4A CC and a chip labeled either TM3db2 or TV3db2. I'm not able to find anything online typing in those strings of letters and numbers and searching websites like s-manuals hasn't yielded anything. It is an sot23-6 package type according to my digikey ruler and I was able to work out some of the pinout from voltages on the board and following the traces around. I'm not really sure what a suitable...
    03-12-2025, 02:10 PM
  • JTaylor
    Allen and Heath Xone S2
    by JTaylor
    Hello everyone.
    I am trying to repair an Allen and Heath Xone S2 mixer but need a schematic. I found the service manual on line but it is missing 4 pages.
    When an input is connected to one of the four line / phono input channels I can hear the music in the cue / headphones but there is no output on the master, the input faders are doing nothing. I can connect the sound input to the mic / line inputs or the external input boards and there is sound on the master output. One of the 74HC4053D Multiplexer/Demultiplexer had blown on the slave PCB so I changed this, I also changed two of...
    05-02-2025, 08:08 AM
  • Tarot Superstars
    Add Stereo Input To Hi-Fi (Sony SONY PMC 107L)
    by Tarot Superstars
    Hi.
    I bought a Cheap HIFI to use as my PC output and speakers and forgot to check if it had an input. It doesn't.
    Is there any way to add a stereo input. I have a bunch of Phono sockets I am not using.
    Where in the circuit is the best place to solder the 3 stereo input wires?
    This is the model and schematics:
    https://www.manualslib.com/manual/91...7l.html#manual
    10-31-2023, 03:23 AM
