LG 37" LCD TV (2005) Model - Switching On and Off
  • Rhothgar
    • May 2015
    • 109
    I seriously do not believe my bad luck.
    I think I am becoming known as the forum's no.1 electronics breaker not fixer!
    I settled done to watch the England v Japan Women's World Cup last night and just as they were about to kick off - NO SIGNAL!
    I switched off then on again. Corrected it then it happened again so I retuned.
    Cannot remember if it was during the tuning but I tried to cancel it by switching off and it wouldn't switch off either with remote control or main power button.
    I think I may then have switched it off at the mains socket.
    When I finally got it working again, it was fine until about 37 minutes in and the TV just switched off so I missed the first England goal!
    I fiddled around a bit more and suddenly it started switching on then immediately off then on and off.
    I have searched the net and this seems to be a common problem with some late LG Smart TV. Obviously this is not a smart tv because of its age and because of its age, I want to keep it working.
    Could this be a capacitor problem? It is the LG 37LP1D model.
    03-31-2024, 02:12 PM
    07-01-2024, 06:34 AM
    After all of...
    07-13-2024, 08:14 PM
    DVR camera recorder switching power supply capacitor failure really
    These cheap non brand capacitors at it again
    Last night we had a power outage [ long drawn out trying three to come back up before going out completely ] and when I went to turn the DVR camera recorder back today no go 3 bad capacitors ( one capacitor no ESR reading on DVR board the other 3 capacitor on the power supply board over 40 ohm this is not a misprint ) on the external switching power supply and one capacitor on the DVR camera recorder board where the power supply that goes to the hard drive disk is
    Well at least I have the cameras back on line I to try the...
    01-22-2022, 06:28 PM
  • michel74
    How does this switching PS work ?
    by michel74
    Yes ! How does this switching PS works ? :-)
    I understand (not in deep, of course) the switching PS principle; typically, I'd expect to get a VCC just to "feed up" the STR or the Switching regulator, but I cannot figure how this VCC is "created" (on a TV switching PSU, I often see some cascaded resistors, but here, I believe that one of the transformer input should make the permanent VCC, but I cannot figure where )
    Thanks for your help. I already wrote some explanation of what I was having and did some measurements here ...
    11-02-2023, 12:35 PM
