I just brought home an old PACO tube based 5Mhz occiloscope from work for restoration, and it has this thing mounted to the top of it, that says Parametric Analyzer... WTF is a parametric analyzer? Whatever it is, there are settings for high, medium, low, and calibrate. It is plugged into both the X and Y inputs of the scope.
Parametric Analyzer?
Tags: None
Re: Parametric Analyzer?
Ive heard of a parametric equalizer for music.....think basically it nulls frequencies at different points.
So I nearly opened my big mouth about the wrong thing (although I would have had to check on it)
Anyway yeah I knew it would be alone some sort of similar line but with regards to measurement
(when I seen parametric I thought "equalizer" then I "read what you typed "analyzer"
I think it was used for semiconductors, curve tracing but not sure how the hell all that works now So I googled it for you.
parametric analyzer
http://tuttle.merc.iastate.edu/ee432...alyzerinfo.htm
this book snip it sort of confirms it.
http://books.google.com/books?id=ymM...hwNy4#PPA18,M1
I've never owned one to have the pleasure of finding out exactly how they work and any stuff I read on them was years ago
So stuff all help to you on how you "use"it
Maybe the links might help
possibly search "semiconductor curve tracer" too
This is off the top of my head so could be wrong.
My day, Decent Cro's etc were very expensive things..the humble Multimeter was your best friend (never heard of Paco but it probably cost a packet in its day)
Hope the links are of some help anyway mate
CheersLast edited by starfury1; 01-06-2008, 03:59 AM.You step into the Road, and if you don't keep your feet, there is no knowing where you may be swept off to." Bilbo Baggins ...
Postcard 32 4-Bit 4-Digit Diagnostic Card PC Analyzer Manual
Diagnostic Card is a powerful diagnostic tool for technicians and administrators to troubleshoot
various problems of IBM compatible PCs. It is easy to install, yet extremely powerful to use. With
Diagnostic Card in hand, you no longer have to go through tedious and time consuming process of
trying to figure out what is wrong with your PC hardware. Diagnostic Card will tell you exactly
what is wrong with your PC in just seconds. It saves you time and money.
Our new and improved design...-
Channel: Schematics and Boardviews
11-01-2024, 06:29 AM -
Hi there, apologies I'm a real noob with this sort of stuff so please bear with me:
A week or two ago my laptop randomly started having the Blue Screen of Death and bootloop every time it booted up. So I tried the recovery options while trying to retain the data: the laptop then said you need a Bitlocker Recovery Key. I never selected for the drive to be bitlocker encrypted so this was really weird to me- I have looked through every Microsoft account I own and none of them have the bitlocker recovery key.
After researching I came across this article: https://dolo... -
by sam_sam_sam2~24 Series Lithium Battery Equalizer For Lipo/Lifepo4/LTO Measurement, Maintenance, Overhaul, Differential Pressure Repair
https://www.aliexpress.us/item/32568...D%21228.0%2120... -
by ktmmotocrossmy mate have very expencive tool with USB port that works only with mouse, not with usbkey.
where to search for fault? - Loading...
