Linear Regulators: Another Option
  • Longbow
    • Jun 2011
    • 623
    I want to bring to your attention a neat switching regulator drop-in replacement for the linear 78XX voltage regulators.
    They come in vertical or horizontal packages and plug right into the holes that might be used for the TO-220. They are more expensive than a 78XX, but might be worth it if you otherwise have to dump a large input voltage through a linear regulator. Using the MuRata part, for example, would avoid the need for a large heat sink when using a 12v. input to a 5v. regulator running at 1 amp.
    Is it plugged in?
    • 31281
    Re: Linear Regulators: Another Option
    not a new idea.
    http://www.rapidonline.com/electrica...0-series-78072
    • mariushm
      • May 2011
      • 3799
      You can always build them by yourself, just get a decent switching regulator IC and build a small pcb.
      See for example AOZ1021 : http://www.digikey.com/product-detai...5-1-ND/1856090
      1.06$ in 25pcs for the IC, 0.5-1$ for inductor, 0.2$ for ceramic capacitors and resistors, maybe 0.2$ for pcb, if you panelize the small boards into a whole panel. So basically, under 2-2.5$ for each, maybe under 1.5$ if you make 250-500 pcs.
      • ben7
        Capaholic
        • Jan 2011
        • 4059
        I don't usually bother to make one myself, unless I really need to, because it takes time and money to design the PCB, get prototypes made, etc... and you might have stability issues, so you'd have to fix those in the design.
        Yes indeed these are not new, I've known about these replacements for a few years now. Only downside is they are switching ... not good in places where you actually NEED a linear regulator, for low noise.
        Muh-soggy-knee
        • bilux
          uP0109: 2A Ultra Low Dropout Linear Regulator equivalent substitute
          by bilux
          I want to find a replacement for uP0109 8pins, and i found this parts:
          uP0109 is "2A Ultra Low Dropout Linear Regulator"
          RT9199 is "Cost-Effective, 2A Peak Sink/Source Bus Termination Regulator"
          FP6137C is "2A BUS TERMINATION REGULATOR"
          can replace uP0109​ by RT9199 or FP6137C ?
          11-01-2024, 12:00 PM
          Acer TravelMate P2510-G2-M-54Q3 + Option Pack Notebook P2 Specification for Upgrade or Repair
          This specification for the Acer TravelMate P2510-G2-M-54Q3 + Option Pack Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P2510-G2-M-54Q3 + Option Pack boardview and P2510-G2-M-54Q3 + Option Pack schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
          09-06-2024, 08:00 AM
          Richtek RT8205L RT8205M Power Supply Controller for Laptop Computer
          The RT8205L RT8205M is a dual step-down, switch mode power supply controller generating logic-supply voltages in battery powered systems. It includes two Pulse-Width Modulation (PWM) controllers adjustable from 2V to 5.5V, and also features fixed 5V/3.3V linear regulators. Each linear regulator provides up to 100mA output current with automatic linear regulator bootstrapping to the PWM outputs. An optional external charge pump can be monitored through SECFB (RT8205M). The RT8205L/M includes on-board power up sequencing, a power good output, internal soft-start, and internal soft-discharge output...
          10-23-2024, 03:58 AM
          Richtek RT8205A RT8205B RT8205C Power Supply Controller for Laptop Computer Datasheet
          The RT8205A RT8205B RT8205C dual step-down, switch-mode power supply controller generates logic-supply voltages in battery-powered systems. The RT8205A/B/C includes two pulse-width modulation (PWM) controllers fixed at 5V/3.3V or adjustable from 2V to 5.5V. An alternative LGATE1 output LG1_CP can be used for external charge pump (RT8205B). And an optional external charge pump can be monitored through SECFB (RT8205C). This device also features 2 linear regulators providing fixed 5V and 3.3V outputs. The linear regulator each provides up to 70mA output current with automatic linear-regulator bootstrapping...
          10-23-2024, 03:37 AM
        • yuii
          ThinkPad W530 - faulty CPU regulators?
          by yuii
          Hello
          I've got two W530 boards, one with K1000M and one with K2000M graphics card. The first one had an issue of turning off under heavy CPU load after about 30 minutes or in idle. GPU load wasn't causing it to shut down. Trying to turn it back on would only make the power LED to come up for about 2 seconds without fan spin or thinklight flash, and that's it. It also wasn't charging the battery after it died.
          Gently pressing the laptop in left upper corner would fix this problem for a couple of days.
          The latter is completely dead and has the same 2-second power blink, nevermind...
          11-01-2023, 02:59 AM
