PC Graphics card
  • newtothis
    • Mar 2013
    • 1556
    • england
    #41
    Re: PC Graphics card
    That isn't my card nor the titan black but its identical
      • 31170
      check the caps under the chip, they obviously take a lot of heat.
      • newtothis
        • Mar 2013
        • 1556
        • england
        #43
        Cheers for all the help but gonna scrap the card, This is beyond my ability to diagnose
          • 31170
          your doing o.k.
          it's just a job that takes patience.
          maybe build a low-ohms meter / meter adapter.
          • newtothis
            • Mar 2013
            • 1556
            • england
            #45
            I have removed every single cap off the board, still no change. the only few left are sitting on top of the GPU itself out of around 30 on there 5 are less then 1 ohm
              • 31170
              when you lifted the gpu,
              did you check it and the board to see if the short moved?
              • newtothis
                • Mar 2013
                • 1556
                • england
                #47
                Nope, Never thought too! lol
                I may pull it off again and see what I get
                  • 31170
                  see i thought you did because you said something about pulling and checking the gpu and ram!
                  • newtothis
                    • Mar 2013
                    • 1556
                    • england
                    #49
                    I tested the GPU itself for a general short (tho it isn't foolproof) but never tested the card itself.... Most graphics cards fail due to bad BGA connections as we know.... So getting rid of the lead free crap and putting leaded solder on is a first on my agenda... Can usually remedy any issues as well as expanding the cards life.
                      • 31170
                      that's pretty funny.
                      as someone who does a lot of work on stuff in unstabe enviroments i remove leaded solder & replace it with tin/copper solder to increase the joint strength so it wont crack again.
                      people constantly blame lead-free solder because of poor cooling or poor choice of flux during manufacturing / repair.
                      • newtothis
                        • Mar 2013
                        • 1556
                        • england
                        #51
                        Lifted the GPU, Short on PCB has gone...... Scrapped
                          • 31170
                          you should check the caps on the gpu package before you use the bin!
                          • Longbow
                            • Jun 2011
                            • 623
                            Interesting troubleshooting adventure. Nice to be able to check out the board with a microscope, too. What you thought was a solder bridge on one of the chips is just a typical way of connecting 2 pins together. They are so close that solder flows over the trace so you can't see it. But, the card would never have worked at all if an unintended solder bridge like that one was really present.
                            May I make a suggestion that would save you a lot of desoldering and lifting of parts? If you identify a short between V+ and ground, the quickest way to find it is to feed some current into the short using an adjustable supply. Keep the current low, but just enough to warm up the offending shorted part. After a while you can feel what part is warm (or find it with an IR temperature probe). Not too surprising that the chip itself shorted given the high heat of operation. Big points for perseverance!
                            Is it plugged in?
                            • newtothis
                              • Mar 2013
                              • 1556
                              • england
                              #54
                              OK so removed caps on top of GPU and still throws a short... Replaced and marked all components I have removed so far as to not get confused. Decided to push 12v into the card with a thermocouple against each corner of the GPU... Bottom right of the GPU is getting hot but nowhere else.... Time to rip the GPU off again I guess as seems the short is there somewhere. As I have already lifted and reballed the GPU I very much doubt its the BGA connections causing exactly the same fault.
                              Is it possible that a short has occurred internally on the PCB as it is a multilayer?
                                • 31170
                                not really.
                                besides, you said the short went with the gpu lifted.
                                if you lift the gpu again, power the card up without it and see if the board warms up there.
                                • newtothis
                                  • Mar 2013
                                  • 1556
                                  • england
                                  #56
                                  Yeah thought it had, Turned out my meter was kaput LOL hence restesting
                                    MSI Gaming GT75 Titan 4K-011 Notebook GT Specification for Upgrade or Repair
                                    This specification for the MSI Gaming GT75 Titan 4K-011 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GT75 Titan 4K-011 boardview and GT75 Titan 4K-011 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                    09-06-2024, 08:44 AM
                                    MSI Gaming GT75 Titan-015 Notebook GT Specification for Upgrade or Repair
                                    This specification for the MSI Gaming GT75 Titan-015 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GT75 Titan-015 boardview and GT75 Titan-015 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                    09-06-2024, 08:40 AM
                                    MSI Gaming GT75 Titan-013 Notebook GT Specification for Upgrade or Repair
                                    This specification for the MSI Gaming GT75 Titan-013 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GT75 Titan-013 boardview and GT75 Titan-013 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                    MSI Gaming GT63 Titan-033 Notebook GT Specification for Upgrade or Repair
                                    This specification for the MSI Gaming GT63 Titan-033 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GT63 Titan-033 boardview and GT63 Titan-033 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                    09-06-2024, 07:58 AM
                                    MSI Gaming GT63 Titan-032 Notebook GT Specification for Upgrade or Repair
                                    This specification for the MSI Gaming GT63 Titan-032 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GT63 Titan-032 boardview and GT63 Titan-032 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
