Samsung HL61A750 TV Sub PCB (BP96-01726B) - need help in identifying repl. parts
  • fun148
    • Feb 2015
    • 38
    • canada
    Need help choosing the replacement parts for:
    1. Inrush Current Limiter (the one at the bottom of the picture right next to the fuse at location NT8115S):
    https://www.badcaps.net/forum/attach...4&d=1423965847
    Resistance at 25c = 5.0 Ω
    Max Steady State Current = 6.0 A
    Thermal Dissipation Constant = 20c
    Thermal Time Constant = 75 seconds
    Beta Constant (25/85c ±10%) = 3000
    Max capacitance (120vac) = 2450μf
    Max capacitance (240vac) = 610μf
    Leading spacing = 8 mm
    Disc Dia. = 15mm*
    *Space is not a problem for this component
    My main problem is that I do not know if the replacement part should have greater or less max capacitance (as listed in the datasheet) than the original part. There are only 5 choices in Digikey.ca, which one should be used?
    http://www.digikey.ca/product-search...=0&pageSize=25
    2. Referring to the attached picture, at the LB801 location, there is a dark inductor with a “152 k” marking on top.
    https://www.badcaps.net/forum/attach...5&d=1423965847
    I think it is a Korean inductor:
    http://kr.gobizkorea.com/blog/kr_cat...&obj_id=830718
    Part no. IND-152K RA08MB
    Inductance (H) = 1.5m
    DC-R(Ω) = 8.500
    R-C(A) = 0.10
    Test Freq.(HZ) = 1k
    Size: 8 mm Dia
    Height: 10 mm
    Can someone confirm if IND-152K is really the one on my board? If so, will the one below be used as a replacement? This is the only choice in Digikey.ca
    http://www.digikey.ca/scripts/DkSear...48871692557960
  • UL161
    Need Help Identifying Parts on a crossover and a few other newbie questions
    by UL161
    Hi I am trying to refurbish this crossover with some higher quality poly-caps/parts... The speaker is a in-wall Polk 65-RT... Key questions I have are:
    1) What in the world is the yellow part on the board (label is MET 1.0J 100V)?... Should I even consider replacing it?
    2) The 470uF cap.... Does anyone know have a suggestion as to where I can find a reasonable audio quality polycap near that value? (or at least 3 160s or the like?) { I don't want to spend $70 just to replace this one if I can) (maybe even someone looking at this circuit could even tell if this cap is important...
    09-29-2024, 03:17 PM
  • Elaion
    Identifying GT730 GPU parts
    by Elaion
    Hi kind people, I have a GT730 card with burnt components can somebody tell me what part it is?...
    10-20-2024, 01:59 AM
  • Mark D
    Samsung UN65JU67ODFXZA Version TD01 Schematic and Parts List
    by Mark D
    The TV is a Samsung UN65JU67ODFXZA Version TD01. I replaced the power source board and the TV is now working, but I decided to try and troubleshoot the old board to fix at the component level. Trying to get a schematic and a parts list has proven to be an issue. Trying on my own, I can't tell you how many times my Norton security has flagged sites as "malicious". I ordered a service manual from ServiceManuals.net, paid $16.99 and got 66 pages of everything BUT schematics and component parts list! Can anyone steer me in the right direction? Some of the surface mounted component parts...
    10-29-2024, 03:15 PM
  • Fr3shGy
    Samsung U32D970 PSU blown up (Identifying Parts)
    by Fr3shGy
    Hi, my U32D970 PSU (BN44-00786A) has blown up. It went out with a loud bang.
    One of the N-Channel Mosfets (OM802C) caused a short and fried the trace and its components connecting to one of the pins of the 6A01 IC.
    I need help to identify 2 SMD resistors which lost their markings
    highlighted in picture 3 (RM812 and RM808).
    Maybe someone can help me identify them, has a schematic or can give me some advice. would be much appreciated.
    6A01 IC datasheet ( https://www.fujielectric.com/company...4-245-2013.pdf )...
    03-25-2023, 01:58 AM
  • 90Ninety
    Coil Whine , buzzing, identifying parts R9 Fury
    by 90Ninety
    I have an R9 Furty Nano ( R9 2XX IIRC ) that I want to put to use , I got it on ebay for quite cheap but, it has some of the worse coil whine I have heard .
    I tried putting a long tube on my ear and hovered it around the card while in use , I cannot pinpoint it . However I my educated guess is , that it the whine is an inductor coil and it is one or all of these in the picture . Does anyone know what part this is and what part I can replace them with .
    Perhaps likely is that I am missing something else it could be , here is a stock picture...
    12-15-2022, 04:18 AM
