Issues with a Sanyo DMC-2020
  • pentium
    • Mar 2006
    • 2778
    The other day I was given from a friend a Sanyo DMC-2020 2GB mp3/video player that was acting weird.
    When I first got it. the only way to get a response from it was when you pressed the power button, Pressing it with hold on or off just gave you a baclkit dark screen and releasing the power button turned it off. I could not find a way to keep it on without holding the power button and no matter how long you held the power button you would never get anything on the screen.
    I brought the thing home yesterday and after a bit more time holing the power button the screen began to slowly dim and now I don't know if it's even responding to the power button.
    I then plug it in to my laptop and the screen lights back up but the computer does not see the player. Unplugging the player immediately extinguishes the backlight. I don't know if it is charging too but I was told that it was fully charged when it was given to me.
    I opened it up and couldn't see anything loose but something tells me there is a cold joint. I also can't seem to download the owners manual so if there is a method to completely clear the unit (could be caused by corruption) I can't do it. Anybody have ideas on what the problem could be?
    Find Nedry!
    Check the Vending machines!!
    <----Computer says I need more beer.
  • kikkoman
    • Jul 2007
    • 691
    Re: Issues with a Sanyo DMC-2020
    Can you measure the voltage of the built-in battery?
    Fully charged it should give 4.1 to 4.2 V. If it's way below 3.5V, it could be a problem related to the charging circuit and/or the battery itself.
    "Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin slitting throats." - H.L. Mencken
    • Tom41
      • Oct 2005
      • 336
      • England
      My sister had an original iPod that had this problem. While connected to mains or to the computer, it would play as normal. Disconnect it from the computer or mains charger, and within 30 seconds the battery was flat and it cut off. This even happened if the iPod was left to charge overnight!
      We decided that the Li-Ion battery inside had reached the end of its useful life, and decided it was too expensive to repair - so got one of the new iPods. Besides, she wanted to put more music and videos on it
      If the Sanyo MP3 player has a built in Li-Ion battery, it may well have reached the end of its useful service life and needs replacing. Is it possible to change the battery yourself, or is it sealed inside?
      I had a PC laptop that had a dead Li-Ion battery. It only gave power for 30 seconds on a full (overnight) charge before it cut off!
      You know there's something wrong when you open your PC and it has vented Rubycons...
      • pentium
        • Mar 2006
        • 2778
        The battery is fine. It's holding a good charge but the player refuses to work with it. I checked the leads and they were okay too.
        Looks like it's on the board.
        Find Nedry!
        • pentium
          • Mar 2006
          • 2778
          Correction. That battery has gone far south. I tried to get to work again today (breaking the hold switch off in the process ) and first thing I did was remove the battery after I left it to charge for a night. Even after a whole night it was still not holding a whole volt so it looks very dead. It's a 3.7V cell and thus I tried the battery in my Razr (it too is a 3.7V battery) and got the same problem. Backlight goes on when power button is pressed but only stays on if you keep holding the power button and nothing else happens. I have also noticed that in both cases (using a battery or connected to a usb port) that the backlight randomly flickers not so much that it's on and off but dimming and brightening). I checked the screen ribbon cable and there is no problems there.
          Macro time!
          Find Nedry!
          • jkruns
            M1 A2338 screen and touchbar issues after cleaning up liquid damage
            by jkruns
            This is my first post after browsing this wonderful treasure trove of knowledge for many, many evenings. I've decided to learn how to fix these things, properly.
            My patient is an A2338 Macbook Pro M1 (late 2020).
            It had some corrosion around JT710 and JT700 caused by liquid spill, as well as against the protective barrier around the USB-C chips UF000 and UF100. So I took the main board out and cleaned it with a toothbrush and alcohol, then with alcohol in an ultrasonic cleaner. Cleaned the touchbar flex connectors as well. The board looks...
            04-22-2024, 06:45 AM
          • x_orange90_x
            Seven Leagues Slot Machine stop button issues
            by x_orange90_x
            I don't know if anyone here has experience with Japanese slot (pachislo) machines, but I sure hope so. I bought this machine last week in semi-working order. It would play and the reels would spin, but the stop buttons would not stop them at all. I found that the high-frequency filtering tantalum capacitor was bad on the reel stop board, along with the fuse being blown. I replaced the fuse and removed the capacitor. I haven't replaced the cap yet because I didn't have one on hand, but it's not necessary for the operation of the machine.
            The issue now is the Stop buttons are intermittently...
            02-12-2025, 10:01 AM
          • aazjo
            A1502 screen only issues
            by aazjo
            I have a MBP A1502 (early 2015, 820-4924) with a screen that will not turn on. I have swapped screens with a cracked test screen and the computer boots and the cracked screen works for both backlight and image. The black/blank screen appears to do nothing.
            I have collected resistant data from the cracked screen connector pins and submitted to OBData server:
            1 PPVOUT_SO_LCDBKLT OL
            3 I2C_BKLT_SCL 9.97M
            4 I2C_BKLT_SDA 9.89M
            5 PP3V3_S0_EDP_R 79.10k
            6 SMBUS_SMC_0_S0_SCL 321k
            7 SMBUS_SMC_0_S0_SDA 323k
            8 EDP_BKLT_PWM ...
            11-04-2021, 11:46 PM
          • reformatt
            by reformatt
            07-31-2025, 08:37 PM
          • smic717394
            by smic717394
            07-25-2024, 10:16 AM
