Digital compact camera dropped
  • Fast Alpha
    • Feb 2013
    • 245
    First I took a few picture then dropped while looking at a girl .
    I had dropped it then the lens would not retract, I then push it back in, now I hear a rattle when I shake it.
    I can turn it on, it states please turn off camera then turn back on again.
    Error message.
    I don't know how to open it up to repair it. I might get a repair by shop, but camera cost £60. The repair price you guessed it.
    Panasonic DMC LS6.
    http://www.cameras.co.uk/reviews/panasonic-dmc-ls6.cfm
    http://www.hse.gov.uk/pubns/indg305.pdf
  • SteveNielsen
    Retired Tech
    • Jun 2012
    • 2327
    Re: Digital compact camera dropped
    You've damaged the mechanicism for the lense assembly. It's probably not worth fixing even if possible.
      • 30931
      did you get a foto of the girl? she must have been impressive!
      • Fast Alpha
        • Feb 2013
        • 245
        She was dressed as THOR with bra out.
        • redwire
          • Dec 2010
          • 3900
          The lens hitting the ground breaks gears and stuff. You could try eBay for the same model camera that is for parts only. I fixed a Nikon compact camera with a similar problem using another that had a broken LCD. It's still a lot of tiny parts and connectors and not fun.
          • SteveNielsen
            Retired Tech
            • Jun 2012
            • 2327
            I've got a Kodak cam that was dropped similarly (no girl dress as Thor invovled though) and the lense extention/retraction mechanism didn't work. It would try to retract and lock up, turn off. I was able to get it to retract by turning it on and off and applying slight pressure in different directions on the sides of the lense housing at the same time until it finally retracted but still would extend when turned on and lock up. I repeated the process and it eventually started to work again, apparently some misaligned gear or whatnot got back into place and with further use and excercize it finally started working without grinding or haning up.
            • RJARRRPCGP
              • Jul 2004
              • 6301
              Lock up on a Kodak, at least the EasyShare M753, usually means a weak battery.
              ASRock B550 PG Velocita
              Ryzen 9 "Vermeer" 5900X
              Arc A770 16 GB
              eVGA Supernova G3 750W
              Alienware AW3423DWF OLED
              • SteveNielsen
                Retired Tech
                • Jun 2012
                • 2327
                Not in this case, it was a mechanical problem.
                • RJARRRPCGP
                  • Jul 2004
                  • 6301
                  BTW, I meant when it freezes like a PC with a bad core OC.
                  Arc A770 16 GB
