Smd component code lfxh b550
  • nassih
    • Oct 2015
    • 280
    • morocco
    Hi I need if someone have this reference code :lfxh b550 this is a smd ic I think an dc-dc converter.tanks
    • 21880
    post a picture
    • truclacicr
      • Apr 2019
      • 352
      • australia
      https://www.analog.com/media/en/tech...ts/ltc3103.pdf
      • nassih
        • Oct 2015
        • 280
        • morocco
        tanks Mr truclacicr its look good,same pinout tomorrow i put pictures for more info
        tanks community
        • nassih
          • Oct 2015
          • 280
          • morocco
          Pinout voltage:
          1 6,1v
          2 3,3v
          3 7,4v
          4 gnd
          5 3.2v
          6 4,1v
          7 6,1v
          8 0,6v
          9 0,4v
          10 6,1v
          • nassih
            • Oct 2015
            • 280
            • morocco
            Some pictures
              LCD LED TV Service Menu Codes
              ALL LCD LED TV SERVICE MENU CODES
              Service Menu Code with Board Name
              China Universal Board / Jumper Board Service Menu Code
              Changhong Ruba Service Menu Code
              Ecostar LED TV Service Menu Code
              Orient LED TV Service Menu Code
              Haier LED TV Service Menu Code
              TCL LED TV Service Menu Code
              Samsung LED TV Service Menu Code
              LG LED TV Service Menu Code
              Videocon LED TV Service Menu Code
              Supra LED TV Service Menu Code
              Toshiba LED TV Service Menu Code
              Symphony LED TV Service Menu Code
              Veste/ LED TV Service Menu Code...
              10-31-2024, 03:58 AM
            • Curtissimo
              HP EliteBook 850 G8 - Error code / Caps Lock permanently on and blinks twice every 6 seconds
              by Curtissimo
              Hi everyone.
              I have a HP Elitebook 850 G8.
              Serial: 5CG2324XM0
              ProdID 6L8D5EC#ABA
              It has a Winbond W25Q256JVEN Chip.
              I need to remove BIOS Password.
              I made a dump with an CHA341A programmer and NeoProgrammer 2.2.0.10.
              Attached my dump.
              I also used the HP Unlocker tool to create an unlocked file (I followed the guidelines)
              I also downloaded latest HP BIOS Update (SP158137) which includes 3 .bin files. I found the Number T76 in my original dump, so I used: T76_01210000.bin
              What I did:...
              08-26-2025, 04:42 AM
            • DynaxSC
              ASUS ROG STRIX B550-I GAMING - M.2_2 port not working correctly with SAMSUNG SSD980 1TB NVME SSD
              by DynaxSC
              I have an really very weired issue with ASUS ROG STRIX B550-I GAMING.
              Some NVME (PCIe) SSD's are not working correctly in the second M.2 socket. An example of it is the SAMSUNG SSD980 1TB NVME SSD.
              Some other NVME (I have only smaller ones) disk do work without any problem, also SAMSUNG disks, eg an MZVPV128HDGM-0000.
              The behaviour is also really very strange, i.e.:
              • The disk shows always up in BIOS - so it is recognized, so far so good
              • POST-ing with this disk with fresh Windows 24H2 installation (done in the M.2_1 socket) in the M.2_2 socket
              02-23-2025, 01:33 PM
            • Sorrow1
              Intergraph TDZ 2000 mainboard post code 2F/2E
              by Sorrow1
              I try to repair an old Intergraph TDZ 2000 from 1998. It is a dual Pentum II machine based on Intel 440LX chipset. There is a non-removable bios chip named PhoenixBios B1787840. I cannot see any physical damage to the board. All caps look OK.
              It shows no picture and POST stops with code 2F/2E regardless whether or not any graphic card is plugged in. If memory is removed, it stops on previous code 28/17 and stars beeping. I tested both CPUs in another machine and I also use RAM from another machine.
              When I recorded video of POST card and played it in slow...
              01-03-2024, 04:13 AM
