Ugreen HDMI splitter missing a pulldown resistor
  • spleenharvester
    • Mar 2010
    • 921
    Odd one I've found. This splitter likes to cut out - on my Xbox Series S the display/audio would randomly go to black for a few seconds - on my PC the monitor would flicker several times before eventually staying on. A few others have reported similar issues. Couldn't be bothered returning it for the sake of £8.
    I pulled it apart and found it is driven by a Texas TS3DV642 mux/demux. There appears to be a missing pulldown resistor on the HPD line, it is just left floating. Adding a 100K pulldown to ground fixes the flickering.
    (Not that this is worth the hassle for an £8 splitter)
    Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
  • badcap111
    Xiaomi mi 9T missing resistor
    by badcap111
    Hi, while trying to replace a broken screen connector on the motherboard, I knocked off a resistor next to the connector, and the resistor vanished. I have tried to find out the value of the resistor by looking at the schematics, but I cannot find the value. The ID of the resistor, or what you should call it, is R6400.
    I don't know if the resistor is necessary for the phone to function, and the connector is still not soldered on to motherboard. I have contacted Xiaomi and asked them if they know the value, but they want a proof of purchase, which I don't have.
    Is...
    08-07-2023, 10:42 AM
  • liquidzorch
    Missing resistor on BQ ILIM pin. DA0P5JMB6D0
    by liquidzorch
    Hello. I can't find the schematics anywhere for this motherboard, does anyone have one, and can give me the resistor value for the BQ728H missing in pic below? I already read the dadsheet, and this resistor value is calculated, so I can't just go with whats in the "typical" diagram.
    On a second note, could this resistor cause it to only boot with the battery and not the charger? It boots fine with a charged battery, but will not turn on with the charger (nor charge). The 19v does not get past the first mosfet, it recieves pulses to turn on, but something is preventing it....
    12-18-2023, 01:56 PM
  • pete61
    Gigabyte 4080 Super Gaming OC with a resistor and three caps missing
    by pete61
    Hi all I have got a gigabyte 4080 super gaming oc with a resistor and three caps missing, Can anybody please tell me what the values for these are, See pic for details, Thanks in advance....
    05-21-2025, 09:46 PM
  • jinu_j
    by jinu_j
    Hi
    05-03-2025, 10:51 PM
  • mugen1903
    da0x36mbae0 missing resistor
    by mugen1903
    Hello friends, the 0x36mbae0 model l motherboard is missing, there are resistors, I would like to thank my friends in advance who will help me with this issue.
    01-07-2025, 02:12 AM
